[OpenLayers-Users] Popup in Openlayers (How to fix the popup?)
Arnd Wippermann
arnd.wippermann at web.de
Thu Jul 16 17:00:31 EDT 2009
I use a couple of movable divs for different tasks
http://gis.ibbeck.de/ginfo/apps/OL27Client/OL27ClientGis.asp?KARTE=k10000
Arnd
_____
Von: Kwong Hu Kiu [mailto:kwonghu at hotmail.com]
Gesendet: Donnerstag, 16. Juli 2009 19:41
An: arnd.wippermann at web.de; users at openlayers.org
Betreff: RE: AW: [OpenLayers-Users] Popup in Openlayers (How to fix the
popup?)
Any example ? I have the map as a fullscreen.
Thanks.
_____
To: kwonghu at hotmail.com
Subject: AW: [OpenLayers-Users] Popup in Openlayers (How to fix the popup?)
Date: Thu, 16 Jul 2009 18:31:52 +0200
Why do you not create an own div element instead of an OpenLayers popup? It
will always be at the same position without calling any events.
Arnd
_____
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Kwong Hu Kiu
Gesendet: Donnerstag, 16. Juli 2009 16:32
An: adube at mapgears.com
Cc: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Popup in Openlayers (How to fix the popup?)
Yes, the moveend is triggered on every pan but it's not moving the popup.
The popup.moveto is always being called.
Any idea ?
> Date: Thu, 16 Jul 2009 09:45:34 -0400
> From: adube at mapgears.com
> CC: users at openlayers.org
> Subject: Re: [OpenLayers-Users] Popup in Openlayers (How to fix the
popup?)
> Hi,
> Could you share more of your code, please ? How do you register you
> event for instance ? The 'moveend' event should be triggered on every pan.
> Regards,
> Alexandre
> Kwong Hu Kiu wrote:
> > I have tried that.
> > Something like
> > if (popup != null)
> > var widthPixel = map.getSize().w - 280;
> > var heightPixel = map.getSize().h - 300;
> > popup.moveTo(new OpenLayers.Pixel(widthPixel,
> > heightPixel));
> > But the popup does not want to move when i pan.
> > It only move if i zoom in/out.
> > I have debug'ed this and "pop.moveTo" is being called whenever i pan.
> > Not really sure if this is a bug.
> > I just want a simple popup that always appear on the lower right corner
> > so user can interact with the map.
> > Regards.
> > > Date: Thu, 16 Jul 2009 08:18:27 -0400
> > popup?)
> > > Hi,
> > > You could register a map 'moveend' event to move the popup again to
> > > the original location. You would need to recalculate the position on
> > > each move.
> > > Regards,
> > > Alexandre
> > > Kwong Hu Kiu wrote:
> > > > Hi,
> > > > I am trying to use the openlayers popup in the map as below.
> > > > if (this.popup == null)
> > > > this.popup = new OpenLayers.Popup();
> > > > this.popup.setBorder("2px solid");
> > > > this.popup.setSize(new OpenLayers.Size(270, 270));
> > > > this.popup.setContentHTML(popupContentHTML);
> > > > this.popup.setOpacity(0.65);
> > > > this.popup.addCloseBox();
> > > > map.addPopup(this.popup);
> > > > this.popup.show();
> > > > else
> > > > this.popup.toggle();
> > > > How do i get it to display in one position (like the lower left
> > > > portion of the screen) ? and always appear there whenever you
pan/zoom
> > > > I figured that i can use popup.moveTo as below.
> > > > this.popup.moveTo(new OpenLayers.Pixel(widthPixel, heightPixel));
> > > > But the popup will move out of that location whenever you pan. It's
> > > > alright when you zoom in/out(always at the lower left) but not pan.
> > > > Please help. Simple problem taking me a while to resolve.
> > > > Cheers.
> > > > _______________________________________________
> > > > Users mailing list
> > > > Users at openlayers.org
> > > > http://openlayers.org/mailman/listinfo/users
> > > Alexandre Dubé
> > > Mapgears
> > > www.mapgears.com
> Alexandre Dubé
> Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090716/751ef9f0/attachment.html
