[OpenLayers-Users] REPEAT QUESTION - How do I prevent my map
from zooming out too far?
jim.meyer at concept-solutions.com
Mon Jul 20 16:30:49 EDT 2009
Hi Andreas,
Thanks for your response. Do these options need to be set for the base
layer or for the map? Also, do you have an example of the values that would
confine my map to just one view of the world?
Again... thanks for your assistance,
Jim
James B. Meyer
Java Programmer
Concept Solutions, Inc.
(703) 472-7838
11600 Sunrise Valley Drive
Suite 300
Reston, VA 20191
-----Original Message-----
From: andreas.hocevar at gmail.com [mailto:andreas.hocevar at gmail.com] On Behalf
Of Andreas Hocevar
Sent: Monday, July 20, 2009 3:22 PM
To: jim.meyer at concept-solutions.com
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] REPEAT QUESTION - How do I prevent my map
there are many ways to do that, combine one or more of the options
below to achieve the result you need:
* set a maxExtent for your base layer
* set a maxResolution for the base layer,
* configure a resolutions or scales array for your base layer
Regards,
Andreas.
On Mon, Jul 20, 2009 at 9:05 PM, <jim.meyer at concept-solutions.com> wrote:
> Hi everyone,
> I had asked this question originally on June 29, 2009 and didnt
receive
> a response
> Currently when I zoom out to the fullest extent available on the
> panzoombar my map shows four copies of the earth. Is there an easy way to
> prevent this from happening?
> It seems that using a singleTile value set to true will do it. But,
> Id prefer to continue to rely upon tiled images. Are there any other
ideas
> out there?
> Thanks,
> Jim
> James B. Meyer
> Java Programmer
> (703) 472-7838
> Suite 300
> Reston, VA 20191
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
