[OpenLayers-Users] overviewmap problem
Xiaodong Song
xdsongy at gmail.com
Thu Jul 23 07:45:21 EDT 2009
Hi everybody,
I have a problem with overviewmap in OpenLayers.
I use GeoServer + GeoWebCache + OpenLayers. In some high resolution levels,
for example level X, when I zoom in from level X-1 to X, the overviewmap
rectangle will disappear (the mini-map in overviewmap window is OK), but
when I zoom out from level X+1 to X, the overviewmap rectangle will appear
(but still missing at some resolutions, not all).
But if removing GeoWebCache, everything is OK, so it's certain the problem
is with GeoWebCache. In GeoWebCache, I set zoomStart 0 and zoomStop 9.
Whether this problem is introduced by improper configuration of resolution
in GeoWebCache?
Thank you!
Xiaodong Song
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090723/7f66309c/attachment.html
