[OpenLayers-Users] Some question to OpenLayers.Protocol.WFS.fromWMSLayer
Andreas Hocevar ahocevar at opengeo.org
Tue Jul 28 10:42:41 EDT 2009
Hi Kai,
Kai Behncke wrote:
> thank you for that hint, but unfortunately it doesn` work (well, the pixel tolerance works but then the coordinate is not fitted and it gives an "empty"-WFS result).
>> var xyz = new OpenLayers.Control.GetFeature(
>>     protocol: OpenLayers.Protocol.WFS.fromWMSLayer(layer),
>>     hover: true,
>>     styleMap: style_obj1
>>     handlerOptions : {
>>       hover: {
>>         pixelTolerance : 10
Almost. The snippet below should work:
    hover: true,
    clickTolerance: 10
Maybe the name of that property (*click*Tolerance) is misleading, but
that one is used for every request. I just fixed the docs, now at least
there is a hint that this is also for requests on hover.
Also note that Control.GetFeature cannot be configured with a styleMap.
You have to do this on the layer.
Regards,
Andreas.
>>>            var xyz = new OpenLayers.Control.GetFeature({
>>>                 hover: true,
>>>             xyz.events.register("hoverfeature", this, function(e) {
>>>         hover.addFeatures([e.feature]);
>>>             map.addControl(xyz);
>>>             xyz.activate();
>>> 2) Even I declared an own style in the "var xyz"-section I still get the
>> typical-wfs-orange-opacity style.
>>> If I write:
>>> var my_feature = new OpenLayers.Feature.Vector(e.feature.geometry,null,
>> style_obj1);
>>> hover.addFeatures([my_feature]);
>>> I get what I want, but I wonder if there is a ways doing something like
>>>  hover.addFeatures([e.feature],{styleMap: style_obj1}); ??? (it doesn`t
>> work in this way).
>>> Thank you very much, Kai
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
