[OpenLayers-Users] Some question to OpenLayers.Protocol.WFS.fromWMSLayer
Marc Jansen jansen at terrestris.de
Tue Jul 28 10:45:25 EDT 2009
Hi Andreas,
Andreas Hocevar schrieb:
> Hi Kai,
> Kai Behncke wrote:
>> thank you for that hint, but unfortunately it doesn` work (well, the pixel tolerance works but then the coordinate is not fitted and it gives an "empty"-WFS result).
>>> var xyz = new OpenLayers.Control.GetFeature(
>>>     protocol: OpenLayers.Protocol.WFS.fromWMSLayer(layer),
>>>     hover: true,
>>>     styleMap: style_obj1
>>>     handlerOptions : {
>>>       hover: {
>>>         pixelTolerance : 10
> Almost. The snippet below should work:
>     hover: true,
>     clickTolerance: 10
> Maybe the name of that property (*click*Tolerance) is misleading, but
> that one is used for every request.
... yipp, that was quite misleading. Thanks for the quick doc update!
Marc
> I just fixed the docs, now at least
> there is a hint that this is also for requests on hover.
> Also note that Control.GetFeature cannot be configured with a styleMap.
> You have to do this on the layer.
> Regards,
