[OpenLayers-Users] Problem to load a WFS
Maxime Phaneuf
maxime.phaneuf at usherbrooke.ca
Fri Jun 5 09:46:48 EDT 2009
Hi Steve
Your mapfile name is paccsante2.map, but in your WFS constructor you're
calling paccsante.map2.
As far as I can see, that must be your problem.
Maxime
Steve.Toutant wrote:
> Hi,
> I set a WFS server that I'm pretty sure works correctly since I get a xml
> file when submitting this to the browser (Unfortunatly you don't have
> access to this domain and I don't have any public domain.)
> http://geo.inspq.rtss.qc.ca/cgi-bin/mapserv.exe?map=/ms4w/paccSante/map/paccsante2.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&TYPENAME=HLM_shp_wfs2
> But I can not load the data from the WFS in open layers or any other
> client such as gaia and gvSig. I can see though a WMS from the same
> mapfile. Here is my openlayers function and below the mapfile.
> I don't get any error message and I can't find a log describing the
> problem.
> Thanks for your help,
> Steve
> /*OpenLayers*/
> function init(){
> var options = {
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("EPSG:4326"),
> //Pour afficher les coord lat long
> units: "m",
> numZoomLevels: 10,
> maxResolution: "auto",
> maxExtent: new OpenLayers.Bounds(-9239517, 5465442,
> -5565974, 9349764)
> map = new OpenLayers.Map( 'map', options );
> /*base map*/
> google = new OpenLayers.Layer.Google( "Google
> Hybrid", { type: G_HYBRID_MAP, 'sphericalMercator': true} );
> /*Overlays*/
> monWFS = new OpenLayers.Layer.WFS(
> "HLM en wfs",
> "http://geo.inspq.rtss.qc.ca/cgi-bin/mapserv.exe?map=/ms4w/paccSante/map/paccsante.map2&",
> {typename: 'HLM_shp_wfs2'},
> { extractAttributes: true}
> hlm = new OpenLayers.Layer.WMS( "HLM",
> "http://geo.inspq.rtss.qc.ca/cgi-bin/mapserv.exe?map=/ms4w/paccSante/map/paccsante2.map&",
> {layers: 'HLM_shp', transparent:
> "true", format:"image/gif"},{isBaseLayer: false, visibility:
> false,singleTile:true}
> map.addLayers([google, hlm, monWFS]);
> map.zoomToMaxExtent();
> map.addControl( new OpenLayers.Control.LayerSwitcher() );
> map.addControl( new OpenLayers.Control.MousePosition() );
> /*map file*/
> MAP
> NAME paccsante2
> UNITS kilometers
> SHAPEPATH '\ms4w\paccSante\data\'
> EXTENT -9239517 5465442 -5565974 9349764
> DEBUG 5
> CONFIG MS_ERRORFILE "/ms4w/logs/mapserver.log"
> RESOLUTION 72
> PROJECTION
> "init=epsg:900913" #si overlay avec google
> END
> IMAGETYPE gif
> OUTPUTFORMAT
> NAME gif
> DRIVER "GD/GIF"
> MIMETYPE "image/gif"
> IMAGEMODE PC256
> EXTENSION "gif"
> TRANSPARENT ON
> END
> WEB
> IMAGEPATH "D:\ms4w\tmp\ms_tmp\"
> IMAGEURL "/ms_tmp/"
> # WMS WFS server settings
> METADATA
> 'wms_title' 'PACC Santé'
> 'wms_onlineresource'
> 'http://geo.inspq.rtss.qc.ca/cgi-bin/mapserv.exe?map=/ms4w/paccSante/map/paccsante.map&'
> 'wms_srs' 'EPSG:4326 EPSG:32198 EPSG:900913'
> 'wms_feature_info_mime_type' "text/html"
> 'wfs_title' 'wfs_paccsante'
> 'wfs_onlineresource'
> 'http://geo.inspq.rtss.qc.ca/cgi-bin/mapserv.exe?map=/ms4w/paccSante/map/paccsante.map2&'
> 'wfs_srs' 'EPSG:900913'
> END
> END #web
> LAYER
> NAME 'HLM_shp'
> TYPE POINT
> DATA 'hlm/hlm_omh'
> DUMP true
> METADATA
> 'wms_title' 'HLM_shp'
> END
> STATUS off
> OPACITY 100
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> STYLE
> COLOR 0 0 255
> SYMBOL 'CIRCLE'
> SIZE 8
> END
> END #class
> END
> LAYER
> NAME 'HLM_shp_wfs2'
> TYPE POINT
> DATA 'hlm/hlm_omh'
> DUMP true
> STATUS ON
> METADATA
> 'wfs_title' 'HLM en wfs'
> 'gml_featureid' 'IDBATIMENT'
> 'gml_include_items' 'all'
> END
> PROJECTION
> "init=epsg:4326"
> END
> CLASS
> NAME "hlm_wfs"
> STYLE
> COLOR 0 0 255
> SYMBOL 'CIRCLE'
> SIZE 8
> END
> TEMPLATE "../template/wfs_hlm.html"
> END #class
> END
> #Circle symbol
> SYMBOL
> NAME 'CIRCLE'
> TYPE ellipse
> FILLED true
> POINTS
> 1 1
> END
> END
> END #map
> Steve Toutant, M. Sc.
> Analyste en géomatique
> Secteur environnement
> Direction des risques biologiques, environnementaux et occupationnels
> Institut national de santé publique du Québec
> 945, avenue Wolfe
> Québec, Qc G1V 5B3
> Tél.: (418) 650-5115 #5281
> Fax.: (418) 654-3144
> steve.toutant at inspq.qc.ca
> http://www.inspq.qc.ca
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Editing-Layers-tp3028763p3030379.html
