[OpenLayers-Users] GetLegendGraphic in div Object like layer
switcher
Rahn Hanno (rahn)
rahn at zhaw.ch
Wed Mar 4 10:41:17 EST 2009
Hello list,
Perhaps somebody can help me. I try to realise a legend with the getlegendgraphic Parameter.
I would send the Request and I then will get an image with the legend graphic with the categories and so on. If I try it in the Browser it works fine.
Now I will put this legendgraphic in an div Object. This div should be inside the mapwindow. The user can open and close this like the LayerSwitcher.
I have no idea how to realise it. It is possible in OpenLayers? I don't know how I can make this div object where I can put in the graphic. I don't want to have it outside the map and I don't want to use the umn mapservers legend Parameter.
Perhaps somebody works with the getlegendparameter and can give me some help.
I hope you understand what I try and my english is not too bad. :-)
Thank you a lot for your help.
Greetings
Hanno Rahn
Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und Natürliche Ressourcen
Fachstelle Geoinformatik
Grüental, Postfach CH-8820 Wädenswil
Tel +41 (0)58 934 5592
Fax +41 (0)58 934 5580
hanno.rahn at zhaw.ch
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090304/817c5c0e/attachment.html
