[OpenLayers-Users] difference between OpenLayers.Layer.WMS and
OpenLayers.Layer.MapServer?
Guillaume Sueur
no-reply at neogeo-online.net
Fri Mar 13 04:04:58 EDT 2009
If you use WMS layer, don't forget to fill up the mandatory attributes
for it in your mapfile.
Regardless of what is in your mapfile, your OpenLayers map lacks of
several settings, like resolutions, projection, maxExtent... Have a look
at the rich collection of example to make it up :
http://www.openlayers.org/dev/examples/example-list.html
Regards,
Guillaume
MeLv1n wAuRaN a écrit :
> Hi Guillaume,
> Thanks for the quick reply..so basically the two are much the same? i
> see, so i will use the wms then. by the way, can you take a look at my
> script below? this does not want to display my map. I'm trying to
> display a basemap (which is the background layer) and 6 overlays where
> each overlay represents a single ESRI shapefile (POINT).
> <html>
> <head>
> <title>Minahasa Utara</title>
> <script src="http://localhost/openlayers/OpenLayers.js"></script>
> </head>
> <body>
> <div style="width:100%; height:100%" id="map"></div>
> <script defer="defer" type="text/javascript">
> var map = new OpenLayers.Map('map');
> var wms = new OpenLayers.Layer.MapServer( "Background Layer",
> "http://localhost/cgi-bin/mapserv.exe", {map:
> 'C:\ms4w\Skripsi\coba.map'} );
> var overlay = new OpenLayers.Layer.WMS("Overlays",
> {layers: ['atm','bank','polisi','rumah
> sakit','terminal','universitas'], format: "image/png"},
> {singleTile: true, minResolution: 1000});
> map.addLayer(wms);
> map.addLayers([overlay]);
> map.setBaseLayer(wms);
> map.zoomToMaxExtent();
> map.addControl(new
> OpenLayers.Control.LayerSwitcher({'ascending':false}));
> </script>
> </body>
> </html>
