[OpenLayers-Users] SelectFeature hover and clickout
Eric Lemoine eric.c2c at gmail.com
Sun Mar 15 10:02:04 EDT 2009
Hi
You can try the patch I just attached to
<http://trac.openlayers.org/ticket/1596>.
Regards,
Eric
On Fri, Mar 13, 2009 at 12:27 AM, Ken Sanderson <ken at rockies.ca> wrote:
> I have been playing around with the sundial example to get the desired
> functionality I am trying to achieve which is basically when I hover
> 'over' the marker with my mouse I get the title, when I click on the
> marker I get the full description.
> I saw in an older post that this was not possible, and indeed I havent
> gotten it to work, as the hover selects the feature already and thus
> clicking on it does not trigger the click function.
> Is this still the case and if so, is there an easy way of doing this? My
> thinking was I might have to read in the KML file and right a script
> that will loop through the markers and add them one at a time, like is
> done inthe popup matrix example. Could I then register a mouse event for
> mouse over and down, would that work? Any suggestions appreciated.
> My other semi related question, when you have a popup from a marker
> symbol it seems confined to the edges of the map div, is there a way to
> specify that it floats over top and can extend out past the boundary of
> the div?
> Thanks,
> Ken
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
