[OpenLayers-Users] Circle Function
Kris Geusebroek
kgeusebroek at xebia.com
Fri May 1 08:43:36 EDT 2009
I have found a much easier way to create a circle.
There is a function in OpenLayers to do that. Works ike this:
var circle =
OpenLayers.Geometry.Polygon.createRegularPolygon(feature.geometry,
10000, 50)
layer.addFeatures(new OpenLayers.Feature.Vector(circle));
the function expects 4 parameters of which I supply 3:
- 1. The point where circlecenter must be at
- 2. The radius in unit's of the map (in my case meters)
- 3. The number of sides (50 makes a nice circle)
The 4th parameter is the angle to start drawing but that doesn't make
sense for a circle
Hope this is of use.
Cheers Kris
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
On Behalf Of Kenny
Sent: Thursday, April 30, 2009 6:28 PM
To: users at openlayers.org
Subject: Re: [OpenLayers-Users] Circle Function
Hi Guys,
Thanks for your help so far, I have a function to create the circles,
and it
seems to be working fine :)
What I can seem to do now is make them have a popup Please se my code so
far....
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>Circle Test</title>
<link rel="stylesheet" href="../theme/default/style.css"
type="text/css"
<link rel="stylesheet" href="style.css" type="text/css" />
<style type="text/css">
p {
width: 500px;
</style>
<script src="http://www.openlayers.com/api/OpenLayers.js"></script>
<script type="text/javascript">
var map, vectorLayer, polygonFeature, selectControl,
selectedFeature;
function init(){
map = new OpenLayers.Map('map');
var layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://labs.metacarta.com/wms/vmap0", {layers:
'basic'}
map.addLayer(layer);
map.addControl(new
OpenLayers.Control.LayerSwitcher());
map.addControl(new OpenLayers.Control.MousePosition());
map.addControl(new OpenLayers.Control.ScaleLine({
bottomOutUnits: "km"}));
map.setCenter(new OpenLayers.LonLat(25.0787,-28.5824),6);
vectorLayer = new OpenLayers.Layer.Vector("Circle");
///////////////Select ////////////////////
selectControl = new
OpenLayers.Control.SelectFeature(vectorLayer,
{onSelect: onFeatureSelect, onUnselect:
onFeatureUnselect});
//select: selectControl;
///////////end //////////////////////
var EARTH_RADIUS_KM = 6371.0088;
var EARTH_RADIUS_METERS = EARTH_RADIUS_KM * 1000.0;
/* degrees to radians */
function geoRadians(deg){
return deg * (Math.PI / 180.0);
/* radians to degrees */
function geoDegrees(rad){
return rad * (180.0 / Math.PI);
function createCircle(lat,lng,radiusKM,line,fill){
var rLat = geoRadians(lat); // radians
var rLon = geoRadians(lng); // radians
var d = radiusKM / EARTH_RADIUS_KM;
var pointList = [];
for (x = 0; x < 360; x += 5) {
var xrad = geoRadians(x);// radians
var tLat = Math.asin(Math.sin(rLat) * Math.cos(d) +
Math.cos(rLat) * Math.sin(d) * Math.cos(xrad));
var tLon = rLon + Math.atan2(Math.sin(xrad) *
Math.sin(d) *
Math.cos(rLat), Math.cos(d)-Math.sin(rLat) * Math.sin(tLat));
Cx = geoDegrees(tLon);
Cy = geoDegrees(tLat);
var newPoint = new
OpenLayers.Geometry.Point(Cx,Cy);
pointList.push(newPoint);
var myStyle = {
strokeColor: line,
fillColor: fill,
fillOpacity: 0.4,
strokeWidth: 1,
pointRadius: 6,
pointerEvents: "visiblePainted"
pointList.push(pointList[0]);
var linearRing = new
OpenLayers.Geometry.LinearRing(pointList);
polygonFeature = new
OpenLayers.Feature.Vector(new
OpenLayers.Geometry.Polygon([linearRing]),null,myStyle);
map.addLayer(vectorLayer);
vectorLayer.addFeatures([polygonFeature]);
//////////////////popup ///////////////////////////
function onPopupClose(evt) {
selectControl.unselect(selectedFeature);
function onFeatureSelect(feature) {
/* selectedFeature = feature;
popup = new OpenLayers.Popup.FramedCloud("chicken",
feature.geometry.getBounds().getCenterLonLat(),
null,
"<div
style='font-size:.8em'>Feature: "
+ feature.id +"<br />Area: " + feature.geometry.getArea()+"</div>",
null, true, onPopupClose);
feature.popup = popup;
map.addPopup(popup);*/
alert("Clicked");
function onFeatureUnselect(feature) {
map.removePopup(feature.popup);
feature.popup.destroy();
feature.popup = null;
////////////////end ////////////////////
</script>
</head>
<body onload="init()">
<div id="map" class="smallmap"></div>
<a
href="javascript:createCircle(-29.688053,28.168945,121.045,'#FF0000','#F
F000
0')">Test 1</a>
<a
href="javascript:createCircle(-22.71539,22.280273,176.809,'#00FF00','#00
FF00
')">Test 2</a>
<a
href="javascript:createCircle(-24.039298,23.983398,129.376,'#0000FF','#0
000F
F')">Test 3</a>
<a
href="javascript:createCircle(-30.039298,20.983398,200.376,'#FFFF00','#F
FFF0
0')">Test 4</a>
</body>
</html>
Any advice
Kenny
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
