[OpenLayers-Users] Point in parrallel with line formula
newbie
shai_mus at hotmail.com
Fri May 1 12:29:48 EDT 2009
Dear Chris,
My data is in Latitude/Longitude. Ok I have used the java
sample code giving in the exercise. Only thing now I need to confirm is that
what is distance output in wat format ? Thank you.
Chris Adams wrote:
> For the second part, you use this equation first, to find 'u':
> http://local.wasp.uwa.edu.au/~pbourke/geometry/pointline/pointline2.gif
> (Where (x1,y1)-(x2,y2) is the line, and (x3,y3) is the point)
> Then, you use this equation:
> x = x1 + u (x2 - x1)
> y = y1 + u (y2 - y1)
> to calculate the new point (x,y)
> Then you have to use some distance equation, to find the distance
> between (x3,y3) and (x,y).
> Is your data in Latitude/Longitude? or Spherical Mercator? or something
> else?
> newbie wrote:
>> Dear Chris,
>> So once I have I have decide whether is +1 or -1 then I
>> must
>> apply the other formula. So must I still apply the first formula to
>> decide
>> +1 or -1 or can I just go to the second formula. Secondly I still cant
>> really see the implementation of the formula. So is there any example
>> implementation of this formula cause I dont know to how to get the answer
>> in
>> metres? Thank you.
>> Chris Adams wrote:
>>> +1 means to the left
>>> -1 means to the right
>>> before calling the 'ccw' function, you'll want to order p0 and p1 so
>>> that p0 has the smaller latitude
>>> To get the distance on the left or right, use the formula linked from my
>>> second response. It finds the closest point, on the line to the other
>>> point, and then you need to take the distance between the two. If you
>>> use Pythagorean theorem, it will give you distance in whatever
>>> measurement the projection of your map is in.
>>> newbie wrote:
>>>> Dear Chris, I am a bit confuse. So the d will be in what measurement
>>>> is it meter or km ? Then if is + or - what is the difference too.
>>>> Thank you.
>>>> Chris Adams wrote:
>>>> Here's a C++ function (Should be easy to convert to JavaScript) /*
>>>> Taken from Robert Sedgewick, Algorithms in C++ */ /* returns
>>>> whether, in traveling from the first to the second to the third
>>>> point, we turn counterclockwise (+1) or not (-1) */ int ccw( Point
>>>> p0, Point p1, Point p2 ) { int dx1, dx2, dy1, dy2; dx1 = p1.x -
>>>> p0.x; dy1 = p1.y - p0.y; dx2 = p2.x - p0.x; dy2 = p2.y - p0.y; if
>>>> (dx1*dy2 > dy1*dx2) return +1; if (dx1*dy2 < dy1*dx2) return -1;
>>>> if ((dx1*dx2 < 0) || (dy1*dy2 < 0)) return -1; if ((dx1*dx1 +
>>>> dy1*dy1) < (dx2*dx2 + dy2*dy2)) return +1; return 0; } >From this
>>>> post on GameDev.net
>>>> http://www.gamedev.net/community/forums/topic.asp?topic_id=457450
>>>> Note it will also return 0 if the point is precisely on the line.
>>>> The deals with turn directions, so it depends on the ordering of
>>>> the points on the line. To get around this, you'll want to swap p0
>>>> and p1, if if p1 is below p0. (If p1's latitude is smaller than
>>>> p0's) newbie wrote: > Dear All, > Just say I got a pair of lat and
>>>> long p1 and p2 and I draw a line > based on both the points. So
>>>> now I want to know if a particular point in the > parallel range
>>>> of say 50m either on left or right sides of the line. How can > I
>>>> decide this what is the formula please ? >
>>>> _______________________________________________ Users mailing list
>>>> Users at openlayers.org http://openlayers.org/mailman/listinfo/users
>>>> View this message in context: Re: Point in parrallel with line formula
>>>> <http://n2.nabble.com/Point-in-parrallel-with-line-formula-tp2742247p2746662.html>
>>>> Sent from the OpenLayers Users mailing list archive
>>>> <http://n2.nabble.com/OpenLayers-Users-f1822463.html> at Nabble.com.
>>>> Users mailing list
>>> Users mailing list
> Users mailing list
View this message in context: http://n2.nabble.com/Point-in-parrallel-with-line-formula-tp2742247p2754090.html
