[OpenLayers-Users] Visibility of features in vector layer
Eric Lemoine
eric.lemoine at camptocamp.com
Tue May 5 12:46:56 EDT 2009
On Tuesday, May 5, 2009, djud <djud at bas.ac.uk> wrote:
> Thanks Heidtmare,
> you're suggestion has fixed the problem! I now set the display style before
> calling drawfeature :
> feature.style.display = 'none';
> layer.drawFeature(feature);
> This is now correct for all OL's internal redraws. I re-enable the feature's
> display setting by:
> feature.style.display = true;
> Not sure this is the correct setting but I think anything other than 'none'
> will work.
Indeed. display: "" may be somewhat preferred.
Cheers,
> Cheers,
> Dave
> djud wrote:
>> Thanks again Heidtmare,
>> I think you're right, the "display: none" is only getting set for the
>> redraw. I'll experiment with making that style setting more permanent.
>> Cheers
> View this message in context: http://n2.nabble.com/Visibility-of-features-in-vector-layer-tp2792029p2795272.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
