[OpenLayers-Users] IE7 popup problem with 2.8 rc2
Frank Broniewski
brfr at metrico.lu
Fri May 8 05:29:43 EDT 2009
Hi list,
I recently tested my maps with the new OL 2.8 rc2 version in order to make the
multiple selectcontrol work. I use framed popups in my maps to display the
data. However I noticed in IE7 that the popup size is not adapted to the
content size, however it is when using OL 2.7.
System is Win Xp64, 32bit Browser version.
I tried to find the css differences, but there aren't any apparent changes
that might cause this behavior, well at least I couldn't find any. If
necessary I can provide a test example.
So I am just reporting this issue. Maybe someone else more skilled in JS and
CSS is able to find out what's going on.
I create my popups as following:
var content = '<div style="width:350;height:250;overflow:auto;"> <h4>' +
feature.attributes.name+'</h4> <p class="popupcode">' +
feature.attributes.description + '</p> </div>';
popup = new OpenLayers.Popup.FramedCloud("ptInfoPopup",
feature.geometry.getBounds().getCenterLonLat(),
null,
content,
null, true, function (evt) {
selectControl.unselect(selectedFeature);
popup.minSize = new OpenLayers.Size(100,150);
popup.maxSize = new OpenLayers.Size(400,300);
Frank Broniewski
Metrico s.àr.l. ( http://www.metrico.lu )
36, rue des Romains
L-5433 Niederdonven
Luxembourg
Fon: +352 26 74 94 28
Fax: +352 26 74 94 99
