[OpenLayers-Users] How can I display a map with a position
changing marker.
Kris Geusebroek
kgeusebroek at xebia.com
Mon May 11 07:09:59 EDT 2009
I'm using a Vector layer with BBOX strategy and WFS protocol with a
layer.refresh({force:true}) to reload the data
The refresh I perform every 5 seconds (with setInterval)
So I don't know which format the lonlat is provided by the JAVA server
but WFS or GML orso would be the easiest to work with I guess.
Hope this helps you a bit.
Cheers KRis
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
On Behalf Of sasi
Sent: Monday, May 11, 2009 11:00 AM
To: users at openlayers.org
Subject: [OpenLayers-Users] How can I display a map with a position
changing marker.
After i displayed a map from the geoserver, i want to add a marker whose
position is changing. The position information(lat,lon) comes from the
web
server(JAVA) and it changes per second.
How can I realize it? What is the code in the Brower and the web server?
Or, which technology should i use? Ajax, HTTPRequest, or the other?
View this message in context:
http://n2.nabble.com/How-can-I-display-a-map-with-a-position-changing-ma
rker.-tp2861920p2861920.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
