[OpenLayers-Users] Firebug Error: Invalid Object Initializer
Nicholas Efremov-Kendall
n.e.kendall at gmail.com
Mon May 11 21:27:15 EDT 2009
Hi all,
I'm getting a firebug error, which is this:
invalid object initializer
var factory=null;if(typeof
GearsFactory!...documentElement.appendChild(factory);}}} error line 224
Here's my code, basically, I'm just trying to get OL to display data in UTM
Zone 32N, which I believe is EPSG:22332 (although there are several))
I apologize for the commented out lines of code.
I'm pretty sure the error's with the mapserver layer.
//Tricking OL's wms to setCenter
var lon = 10.8804;
var lat = 33.7817;
var zoom = 10;
var myproj = new OpenLayers.Projection("EPSG:22332");
//var myproj = new OpenLayers.Projection("EPSG:4326");
var map, layer;
function init(){
// Default WMS from Metacarta
map = new OpenLayers.Map('map',
maxExtent: new OpenLayers.Bounds (656782.661, 3720728.22,
693473.18, 3754557.09),
maxResolution: "auto",
projection: "myproj"
// var myBaseLayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
// "http://labs.metacarta.com/wms/vmap0", {layers: 'basic'}
// map.addLayer(myBaseLayer);
// var jerbaSites =(new OpenLayers.Layer.GML("Jerba_sites",
"kml/doc.kml",
// projection: new OpenLayers.Projection ("EPSG:4326"),
// format: OpenLayers.Format.KML,
// formatOptions: {
// extractStyles: true,
// extractAttributes: true,
// maxDepth: 2
// map.addLayer(jerbaSites);
var mapserv = new OpenLayers.Layer.WMS( "Jerba",
"http://localhost/cgi-bin/mapserv.exe",
map: 'C:/ms4w/apache/htdocs/oltest/Jerba.map',
layers: "satt", "sites", "soils"
map.addLayer(mapserv);
// var kmlTest = new OpenLayers.Layer.GML("KML_Test",
"kml/jerba_site.kml",
// { projection: new OpenLayers.Projection ("EPSG:4326"), format:
OpenLayers.Format.KML, formatOptions: {extractStyles: true,
// maxDepth: 2
// map.addLayer(kmlTest);
// Map Controls
map.addControl( new OpenLayers.Control.LayerSwitcher());
map.addControl( new OpenLayers.Control.MousePosition());
map.addControl( new OpenLayers.Control.OverviewMap());
map.addControl( new OpenLayers.Control.ScaleLine());
map.addControl(new OpenLayers.Control.Permalink());
map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
</script>
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090511/cdf94410/attachment.html
