[OpenLayers-Users] icons displaced in kml layer
Christopher Schmidt
crschmidt at metacarta.com
Tue May 12 08:48:57 EDT 2009
On Tue, May 12, 2009 at 02:10:37PM +0200, Emilio López Pasamontes wrote:
> Hi,
> i`m using google and kml layer, The problem is that the icons that uses the
> kml to refer the placemark are displaced in the coordinates upwards.
> However, the ballon mark well the point. Anyone can help me.
THis is probably
http://faq.openlayers.org/vector-related-questions/why-dont-my-vector-features-work-over-google-yahoo-virtual-earth-etc/
> Best Regards and sorry for my english
> function init(){
> var options = {
> controls: []
> var map = new OpenLayers.Map('map', options);
> map.projection= new OpenLayers.Projection("EPSG:4326");
> map.maxExtent = new
> OpenLayers.Bounds(-5.84473,38.11727,-0.40649,41.36032);
> map.minScale=4000000;
> map.maxScale=3000;
> var gphy = new OpenLayers.Layer.Google(
> "Google Physical",
> {type: G_PHYSICAL_MAP}
> var gmap = new OpenLayers.Layer.Google(
> "Google Streets"
> // the default
> var ghyb = new OpenLayers.Layer.Google(
> "Google Hybrid",
> {type: G_HYBRID_MAP}
> var gsat = new OpenLayers.Layer.Google(
> "Google Satellite",
> {type: G_SATELLITE_MAP}
> var pruebaKml = new OpenLayers.Layer.GML("Equipamientos",
> "http://prej2ee.cit.jclm.es/CatalogoTIC/kml/<?= $_GET['fichkml'];?>", {
> projection: map.projection,
> format: OpenLayers.Format.KML,
> formatOptions: {
> extractStyles: true,
> extractAttributes: true
> pruebaKml.displayInLayerSwitcher=false;
> map.addLayer(pruebaKml);
> map.addLayers([gphy, gmap, ghyb, gsat]);
> var selectControl = new
> OpenLayers.Control.SelectFeature(pruebaKml,
> {onSelect: onFeatureSelect, onUnselect:
> onFeatureUnselect});
> map.addControl(selectControl);
> selectControl.activate();
> var nav = new OpenLayers.Control.NavigationHistory();
> map.addControl(nav);
> var navegacion = new OpenLayers.Control.NavToolbar();
> var barraZoom = new OpenLayers.Control.PanZoomBar();
> var posicionPuntero = new OpenLayers.Control.MousePosition();
> var escalaNumero = new OpenLayers.Control.Scale();
> var escalaLinea = new OpenLayers.Control.ScaleLine();
> var panel = new OpenLayers.Control.Panel({defaultControl:
> navegacion});
> panel.addControls([nav.next, nav.previous]);
> panel.addControls([posicionPuntero]);
> panel.addControls(escalaNumero);
> panel.addControls(escalaLinea);
> panel.addControls(navegacion);
> panel.addControls(barraZoom);
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.addControl(panel);
> /* var control = new OpenLayers.Control();
> OpenLayers.Util.extend(control, {
> draw: function () {
> // this Handler.Box will intercept the
> shift-mousedown
> // before Control.MouseDefault gets to see it
> this.box = new OpenLayers.Handler.Box( control,
> {"done": this.notice},
> {keyMask: OpenLayers.Handler.MOD_SHIFT});
> this.box.activate();
> notice: function (bounds) {
> OpenLayers.Console.userError(bounds);
> map.addControl(control); */
> // map.setCenter(new OpenLayers.LonLat(-3, 39), 9); //Centrar
> el mapa
> map.zoomToMaxExtent();
> function onFeatureSelect(feature) {
> selectedFeature = feature;
> popup = new OpenLayers.Popup.FramedCloud("chicken",
> feature.geometry.getBounds().getCenterLonLat(),
> new OpenLayers.Size(100,100),
> "<h2>"+feature.attributes.name +
> "</h2>" + feature.attributes.description,
> null, true, onPopupClose);
> feature.popup = popup;
> map.addPopup(popup);
> function onPopupClose(evt) {
> selectControl.unselect(selectedFeature);
> function onFeatureUnselect(feature) {
> map.removePopup(feature.popup);
> feature.popup.destroy();
> feature.popup = null;
> </script>
> </head>
> <body onload="init()">
> <!-- <div id="paneldiv" title="paneldiv" class="olControlNavToolbar"></div>
> <div id="map" class title="map"></div>
> </body>
> __________________________________
> Dep. Desarrollo. Serv. Informática
> Consej. Industria, Energía y M.A. (JCCM)
> emiliol at jccm.es
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
