[OpenLayers-Users] icons displaced in kml layer
Emilio López Pasamontes emiliol at jccm.es
Tue May 12 09:22:41 EDT 2009
 Thank´s Christopher, but
 What i do not understand then is why the ballon yes marks the exact point?
> -----Mensaje original-----
> De: Christopher Schmidt [mailto:crschmidt at metacarta.com]
> Enviado el: martes, 12 de mayo de 2009 14:49
> Para: Emilio López Pasamontes
> CC: users at openlayers.org
> Asunto: Re: [OpenLayers-Users] icons displaced in kml layer
> On Tue, May 12, 2009 at 02:10:37PM +0200, Emilio López
> Pasamontes wrote:
> > Hi,
> > i`m using google and kml layer, The problem is that the icons that
> > uses the kml to refer the placemark are displaced in the
> coordinates upwards.
> > However, the ballon mark well the point. Anyone can help me.
> THis is probably
> http://faq.openlayers.org/vector-related-questions/why-dont-my
> -vector-features-work-over-google-yahoo-virtual-earth-etc/
> > Best Regards and sorry for my english
> > function init(){
> > 		  var options = {
> >                     controls: []
> >           var map = new OpenLayers.Map('map', options);
> >         map.projection= new OpenLayers.Projection("EPSG:4326");
> >         map.maxExtent = new
> > OpenLayers.Bounds(-5.84473,38.11727,-0.40649,41.36032);
> >         map.minScale=4000000;
> >         map.maxScale=3000;
> > 			  var gphy = new OpenLayers.Layer.Google(
> >                 "Google Physical",
> > 			   {type: G_PHYSICAL_MAP}
> >             var gmap = new OpenLayers.Layer.Google(
> >                 "Google Streets"
> > 			 // the default
> >             var ghyb = new OpenLayers.Layer.Google(
> >                 "Google Hybrid",
> >                 {type: G_HYBRID_MAP}
> >             var gsat = new OpenLayers.Layer.Google(
> >                 "Google Satellite",
> >                 {type: G_SATELLITE_MAP}
> >         var pruebaKml = new OpenLayers.Layer.GML("Equipamientos",
> > "http://prej2ee.cit.jclm.es/CatalogoTIC/kml/<?=
> $_GET['fichkml'];?>", {
> > 		           projection: map.projection,
> > 				   format: OpenLayers.Format.KML,
> >             	   formatOptions: {
> >                        extractStyles: true,
> >                        extractAttributes: true
> >             pruebaKml.displayInLayerSwitcher=false;
> > 	 map.addLayer(pruebaKml);
> > 	 map.addLayers([gphy, gmap, ghyb, gsat]);
> >            var selectControl = new
> > OpenLayers.Control.SelectFeature(pruebaKml,
> >                       {onSelect: onFeatureSelect, onUnselect:
> > onFeatureUnselect});
> >           map.addControl(selectControl);
> >           selectControl.activate();
> >           var  nav = new OpenLayers.Control.NavigationHistory();
> >           map.addControl(nav);
> >           var navegacion = new OpenLayers.Control.NavToolbar();
> >           var barraZoom = new OpenLayers.Control.PanZoomBar();
> >           var posicionPuntero = new
> OpenLayers.Control.MousePosition();
> >           var escalaNumero = new OpenLayers.Control.Scale();
> >           var escalaLinea = new OpenLayers.Control.ScaleLine();
> >           var panel = new OpenLayers.Control.Panel({defaultControl:
> > navegacion});
> >            panel.addControls([nav.next, nav.previous]);
> >            panel.addControls([posicionPuntero]);
> >            panel.addControls(escalaNumero);
> >            panel.addControls(escalaLinea);
> >           panel.addControls(navegacion);
> >           panel.addControls(barraZoom);
> >           map.addControl(new OpenLayers.Control.LayerSwitcher());
> >           map.addControl(panel);
> >        /*    var control = new OpenLayers.Control();
> >                 OpenLayers.Util.extend(control, {
> >                      draw: function () {
> >                          // this Handler.Box will intercept the
> > shift-mousedown
> >                          // before Control.MouseDefault
> gets to see it
> >                          this.box = new
> OpenLayers.Handler.Box( control,
> >                              {"done": this.notice},
> >                              {keyMask:
> OpenLayers.Handler.MOD_SHIFT});
> >                          this.box.activate();
> >                     notice: function (bounds) {
> >                          OpenLayers.Console.userError(bounds);
> >                  map.addControl(control); */
> >            //   map.setCenter(new OpenLayers.LonLat(-3,
> 39), 9); //Centrar
> > el mapa
> >            map.zoomToMaxExtent();
> >               function onFeatureSelect(feature) {
> >                   selectedFeature = feature;
> >                   popup = new
> OpenLayers.Popup.FramedCloud("chicken",
> > feature.geometry.getBounds().getCenterLonLat(),
> >                                            new
> OpenLayers.Size(100,100),
> > "<h2>"+feature.attributes.name + "</h2>" +
> feature.attributes.description,
> >                                            null, true,
> onPopupClose);
> >                   feature.popup = popup;
> >                   map.addPopup(popup);
> >               function onPopupClose(evt) {
> >                   selectControl.unselect(selectedFeature);
> >               function onFeatureUnselect(feature) {
> >                   map.removePopup(feature.popup);
> >                   feature.popup.destroy();
> >                   feature.popup = null;
> >             </script>
> > </head>
> > <body onload="init()">
> > <!-- <div id="paneldiv" title="paneldiv"
> > class="olControlNavToolbar"></div>
> >  <div id="map" class title="map"></div> </body>
> > __________________________________
> > Dep. Desarrollo. Serv. Informática
> > Consej. Industria, Energía y M.A. (JCCM) emiliol at jccm.es
> > Users mailing list
> > Users at openlayers.org
> > http://openlayers.org/mailman/listinfo/users
> Christopher Schmidt
> MetaCarta
