[OpenLayers-Users] Virtual Earth Issue
willson talentp1982 at yahoo.com.cn
Wed May 13 05:48:03 EDT 2009
I try to use the "spherical-mercator" example in openlayers/example to
display mycity. I just change the map options "maxResolution" and
"maxExtent". The question is : the map doesn't display mycity but whole
china, when I zoom in, the map center goes to africa, and the map can't pan.
All seems strange.
Here is the code, any help would be appreciate!
<html xmlns="http://www.w3.org/1999/xhtml">
  <head>
    <link rel="stylesheet" href="../theme/default/style.css" type="text/css"
    <link rel="stylesheet" href="style.css" type="text/css" />
    <style type="text/css">
        .olControlAttribution { bottom: 0px!important }
        #map {
            height: 512px;
    </style>
    <script
src="http://dev.ditu.live.com/mapcontrol/mapcontrol.ashx?v=6.1"></script>
    <script src="../lib/OpenLayers.js"></script>
    <script type="text/javascript">
        // make map available for easy debugging
        var map;
        // avoid pink tiles
        OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
        OpenLayers.Util.onImageLoadErrorColor = "transparent";
        function init(){
            var options = {
                maxResolution: 0.002805990515625,
                maxExtent: new OpenLayers.Bounds(113.03035471400001,
22.125695214,
113.74868828599999, 22.844028786)
            map = new OpenLayers.Map('map', options);
            // create Virtual Earth layers
            var veroad = new OpenLayers.Layer.VirtualEarth(
                "Virtual Earth Roads",
                {'type': VEMapStyle.Road, 'sphericalMercator': true}
            var veaer = new OpenLayers.Layer.VirtualEarth(
                "Virtual Earth Aerial",
                {'type': VEMapStyle.Aerial, 'sphericalMercator': true}
            var vehyb = new OpenLayers.Layer.VirtualEarth(
                "Virtual Earth Hybrid",
                {'type': VEMapStyle.Hybrid, 'sphericalMercator': true}
            map.addLayers([veroad, veaer, vehyb]);
            map.addControl(new OpenLayers.Control.LayerSwitcher());
            map.addControl(new OpenLayers.Control.EditingToolbar(vector));
            map.addControl(new OpenLayers.Control.Permalink());
            map.addControl(new OpenLayers.Control.MousePosition());
            if (!map.getCenter()) {map.zoomToMaxExtent()}
    </script>
  </head>
  <body onload="init()">
    <h1 id="title">OpenLayers Spherical Mercator Example</h1>
    <div id="tags">
    </div>
    <div id="map" class="smallmap"></div>
    <div id="docs">
    </div>
  </body>
</html>
View this message in context: http://n2.nabble.com/Virtual-Earth-Issue-tp2880849p2880849.html
