[OpenLayers-Users] Virtual Earth Issue
Christopher Schmidt
crschmidt at metacarta.com
Wed May 13 07:26:32 EDT 2009
On Wed, May 13, 2009 at 02:48:03AM -0700, willson wrote:
> I try to use the "spherical-mercator" example in openlayers/example to
> display mycity. I just change the map options "maxResolution" and
> "maxExtent".
You can't do this -- at least not easily -- with spherical mercator layers.
I recommend using 'restrictedExtent' for the latter, and I don't think
there's a way to do the former.
-- Chris
> The question is : the map doesn't display mycity but whole
> china, when I zoom in, the map center goes to africa, and the map can't pan.
> All seems strange.
> Here is the code, any help would be appreciate!
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <link rel="stylesheet" href="../theme/default/style.css" type="text/css"
> <link rel="stylesheet" href="style.css" type="text/css" />
> <style type="text/css">
> .olControlAttribution { bottom: 0px!important }
> #map {
> height: 512px;
> </style>
> <script
> src="http://dev.ditu.live.com/mapcontrol/mapcontrol.ashx?v=6.1"></script>
> <script src="../lib/OpenLayers.js"></script>
> <script type="text/javascript">
> // make map available for easy debugging
> var map;
> // avoid pink tiles
> OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
> OpenLayers.Util.onImageLoadErrorColor = "transparent";
> function init(){
> var options = {
> maxResolution: 0.002805990515625,
> maxExtent: new OpenLayers.Bounds(113.03035471400001,
> 22.125695214,
> 113.74868828599999, 22.844028786)
> map = new OpenLayers.Map('map', options);
> // create Virtual Earth layers
> var veroad = new OpenLayers.Layer.VirtualEarth(
> "Virtual Earth Roads",
> {'type': VEMapStyle.Road, 'sphericalMercator': true}
> var veaer = new OpenLayers.Layer.VirtualEarth(
> "Virtual Earth Aerial",
> {'type': VEMapStyle.Aerial, 'sphericalMercator': true}
> var vehyb = new OpenLayers.Layer.VirtualEarth(
> "Virtual Earth Hybrid",
> {'type': VEMapStyle.Hybrid, 'sphericalMercator': true}
> map.addLayers([veroad, veaer, vehyb]);
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.addControl(new OpenLayers.Control.EditingToolbar(vector));
> map.addControl(new OpenLayers.Control.Permalink());
> map.addControl(new OpenLayers.Control.MousePosition());
> if (!map.getCenter()) {map.zoomToMaxExtent()}
> </script>
> </head>
> <body onload="init()">
> <h1 id="title">OpenLayers Spherical Mercator Example</h1>
> <div id="tags">
> </div>
> <div id="map" class="smallmap"></div>
> <div id="docs">
> </div>
> </body>
> </html>
> View this message in context: http://n2.nabble.com/Virtual-Earth-Issue-tp2880849p2880849.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
