[OpenLayers-Users] Virtual Earth Issue
willson
talentp1982 at yahoo.com.cn
Wed May 13 12:57:54 EDT 2009
I try the 'restrictedExtent' option, but nothing change. Maybe I need to use
virtual earth alone without openlayers in my case?
Christopher Schmidt-2 wrote:
> On Wed, May 13, 2009 at 02:48:03AM -0700, willson wrote:
>> I try to use the "spherical-mercator" example in openlayers/example to
>> display mycity. I just change the map options "maxResolution" and
>> "maxExtent".
> You can't do this -- at least not easily -- with spherical mercator
> layers.
> I recommend using 'restrictedExtent' for the latter, and I don't think
> there's a way to do the former.
> -- Chris
>> The question is : the map doesn't display mycity but whole
>> china, when I zoom in, the map center goes to africa, and the map can't
>> pan.
>> All seems strange.
>> Here is the code, any help would be appreciate!
>> <html xmlns="http://www.w3.org/1999/xhtml">
>> <head>
>> <link rel="stylesheet" href="../theme/default/style.css"
>> type="text/css"
>> <link rel="stylesheet" href="style.css" type="text/css" />
>> <style type="text/css">
>> .olControlAttribution { bottom: 0px!important }
>> #map {
>> height: 512px;
>> </style>
>> <script
>> src="http://dev.ditu.live.com/mapcontrol/mapcontrol.ashx?v=6.1"></script>
>> <script src="../lib/OpenLayers.js"></script>
>> <script type="text/javascript">
>> // make map available for easy debugging
>> var map;
>> // avoid pink tiles
>> OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
>> OpenLayers.Util.onImageLoadErrorColor = "transparent";
>> function init(){
>> var options = {
>> maxResolution: 0.002805990515625,
>> maxExtent: new OpenLayers.Bounds(113.03035471400001,
>> 22.125695214,
>> 113.74868828599999, 22.844028786)
>> map = new OpenLayers.Map('map', options);
>> // create Virtual Earth layers
>> var veroad = new OpenLayers.Layer.VirtualEarth(
>> "Virtual Earth Roads",
>> {'type': VEMapStyle.Road, 'sphericalMercator': true}
>> var veaer = new OpenLayers.Layer.VirtualEarth(
>> "Virtual Earth Aerial",
>> {'type': VEMapStyle.Aerial, 'sphericalMercator': true}
>> var vehyb = new OpenLayers.Layer.VirtualEarth(
>> "Virtual Earth Hybrid",
>> {'type': VEMapStyle.Hybrid, 'sphericalMercator': true}
>> map.addLayers([veroad, veaer, vehyb]);
>> map.addControl(new OpenLayers.Control.LayerSwitcher());
>> map.addControl(new
>> OpenLayers.Control.EditingToolbar(vector));
>> map.addControl(new OpenLayers.Control.Permalink());
>> map.addControl(new OpenLayers.Control.MousePosition());
>> if (!map.getCenter()) {map.zoomToMaxExtent()}
>> </script>
>> </head>
>> <body onload="init()">
>> <h1 id="title">OpenLayers Spherical Mercator Example</h1>
>> <div id="tags">
>> </div>
>> <div id="map" class="smallmap"></div>
>> <div id="docs">
>> </div>
>> </body>
>> </html>
>> View this message in context:
>> http://n2.nabble.com/Virtual-Earth-Issue-tp2880849p2880849.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Christopher Schmidt
> MetaCarta
> Users mailing list
View this message in context: http://n2.nabble.com/Virtual-Earth-Issue-tp2880849p2885129.html
