[OpenLayers-Users] openlayers single file librarry problem
Joanne Cook j.cook at oxfordarch.co.uk
Wed May 13 07:11:32 EDT 2009
Hi All,
I'm not totally sure if this is an openlayers issue or related to mapfish, but I am having problems building a single file version of the openlayers libraries.
I start in /var/www/mapfish/client/mfbase/openlayers/build. The (mapfish) documentation suggests that I should be able to state the location of the file I am trying to create, so I run:
sudo ./build.py full.cfg /var/www/scripts/openlayers_sfl.js
This works to the extent that it creates the file, and most elements work OK in the web page. However, it can't find the image folder or the theme folder, so I don't have the navigation elements, and firebug shows me that it's looking for them in the root folder /var/www, so /var/www/theme and /var/www/img. The same happens if I change the build path to /var/www/mapfish/client/mfbase/openlayers/lib/openlayers_sfl.js.
Clearly I can copy the img and theme folders into my root folder, but is there something I'm missing about building the library?
Thanks
Jo
Joanne Cook
Senior IT Support and Development
Oxford Archaeology (North)
01524 880212
http://thehumanjourney.net
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
