[OpenLayers-Users] Is it possible to get openlayers version 2.8?
Christopher Schmidt
crschmidt at metacarta.com
Wed May 13 16:32:56 EDT 2009
On Wed, May 13, 2009 at 04:23:24PM -0400, Stéphane Poirier wrote:
> I am using the hosted version http://www.openlayers.org/api/OpenLayers.js,
> is this 2.7 or 2.8? Is it possible to download the 2.8?
2.7.
http://openlayers.org/download/OpenLayers-2.8-rc2.zip
And, as described in :
http://openlayers.org/pipermail/dev/2009-May/004807.html
http://openlayers.org/api/2.8-rc2/OpenLayers.js
> Thanks anyway for trying.
> Stephane
> ----- Original Message -----
> From: "Christopher Schmidt" <crschmidt at metacarta.com>
> To: "Christopher Schmidt" <christopher.schmidt at metacarta.com>
> Cc: "Stéphane Poirier" <Stephane.Poirier at USherbrooke.CA>;
> <users at openlayers.org>
> Sent: Wednesday, May 13, 2009 15:32
> Subject: Re: [OpenLayers-Users] How to use layer.events.register() and
> layer.events.on()?
> On Wed, May 13, 2009 at 11:28:57AM -0400, Christopher Schmidt wrote:
> > On Wed, May 13, 2009 at 11:13:38AM -0400, Stéphane Poirier wrote:
> > > Hi All (and Tim),
> > > Catching events using predefined function hook works fine for me (case 2
> > > and 3),
> > > but I do not have any success catching events using
> > > layer.events.register (case
> > > 4) nor layer.events.on (case 5). What do I do wrong? Should
> > > layer.events.register and/or layer.events.on be used before the layer is
> > > created? And what is the difference between these two?
> > > //1) create layer
> > > rectangleLayer=new OpenLayers.Layer.Vector("Selection");
> > > //2) works fine
> > > rectangleLayer.preFeatureInsert=function(feature)
> > > feature_tobeinserted();
> > > //3) works fine
> > > rectangleLayer.onFeatureInsert=function(feature)
> > > feature_inserted();
> > > //4) does not seem to catch event
> > > rectangleLayer.events.register("sketchcomplete",rectangleLayer,
> > > function(event){ var feature = event.feature;
> > > return (feature.geometry.getArea() > 10); // false to not add
> > The order of arguments in this one is wrong: it should be
> > ("sketchcomplete", function(){}). (The rectangleLayer is totally
> > unneccesary in the given function.)
> Actually, my memory was playing tricks on me here. My statement is
> wrong.
> Out of curiousity, are you using OpenLayers 2.8? sketchcomplete doesn't
> exist in OpenLayers 2.7.
> > > //5) does not seem to catch event
> > > rectangleLayer.events.on({
> > > sketchcomplete: function(event) {
> > > Regards,
> > > Stéphane Poirier
> > > Professionel de recherche au CARTEL
> > > Centre d'Applications et de Recherches en Télédétection
> > > Département de géomatique appliquée
> > > Université de Sherbrooke
> > > Sherbrooke (Québec), CANADA J1K 2R1
> > > Tel.: (+1 819) 821 8000 #61904
> > > Fax.: (+1 819) 821 7944
> > > Stephane.Poirier at USherbrooke.ca
> > > http://www.usherbrooke.ca/cartel
> > > _______________________________________________
> > > Users mailing list
> > > Users at openlayers.org
> > > http://openlayers.org/mailman/listinfo/users
> > Christopher Schmidt
> > MetaCarta
> > Users mailing list
> Christopher Schmidt
> MetaCarta
Christopher Schmidt
MetaCarta
