[OpenLayers-Users] Popup problems on different GML layers with
GeoRSS format
Simo D
simone.dalmasso at gmail.com
Thu May 14 06:53:56 EDT 2009
Thanks Christopher.
Now I downloaded the trunk SelectFeature, RootContainer and Openlayers.js.
I modified my code like this:
var popups = new
OpenLayers.Control.SelectFeature([gdacs_earth,gdacs_flood,gdacs_cyclones],
GeorssPopups.init());
map.addControl(popups);
popups.activate();
But nothing changes...is there something wrong?
Thanks in advance.
Simone.
Christopher Schmidt-2 wrote:
> On Wed, May 13, 2009 at 01:13:01PM -0700, Simo D wrote:
>> Hi list, I'm trying to add custom popups on three GML layers which
>> contains
>> GeoRSS feed.
>> My code is composed by three layers declarated like this.
>> var gdacs_earth = new OpenLayers.Layer.GML("Earthquakes (GDACS)",
>> "feedaddress", {format: georss_format, styleMap:
>> createStyle('iconpath')});
>> Where georss_format is var georss_format = new
>> OpenLayers.Format.GeoRSS(in_options);
>> Then i attach three var eqpopups = new
>> OpenLayers.Control.SelectFeature(gdacs_earth, GeorssPopups.init());
>> map.addControl(eqpopups); eqpopups.activate();
> Can't do that. Gotta do one, with three layers passed in the first arg,
> and that will only work in 2.8/trunk.
> -- Chris
>> obviously with different variable names.
>> GeorssPopups is a hash:
>> var GeorssPopups = {
>> init: function(){
>> return {onSelect: this.onFeatureSelect, onUnselect:
>> this.onFeatureUnselect};
>> onFeatureSelect: function(feature){
>> var popup = new OpenLayers.Popup.FramedCloud("featurePopup",
>> feature.geometry.getBounds().getCenterLonLat(),
>> new OpenLayers.Size(100,100),
>> "<h2>"+feature.attributes.title + "</h2>" +
>> feature.attributes.description,
>> null, true,
>> function(){map.removePopup(feature.popup);
>> feature.popup.destroy();
>> feature.popup = null;});
>> feature.popup = popup;
>> map.addPopup(popup);
>> onFeatureUnselect: function(feature) {
>> if (feature.popup) {
>> The problem is that on most browsers this solution works only for the
>> last
>> layer declarated except for Safari 4 where all works fine.
> Safari 4 is whacked. The former is the expected behavior. This is
> because browsers will not let us catch events through the top SVG
> element on the lower level elements. As a result, we've extended the
> SelectFeature control to be able to take efeatures from *all* layers and
> put them in the same SVG element.
>> It seems that the listener associated with the SelectFeture method
>> listens
>> only on the last GML layer declared.
>> If I declare one layer with GML class
>> and others with the GeoRSS class it works.
> Yes, Because the GeoRSS class uses markers, and doens't have the same
> behavior because no SVG is involved.
>> I also tried to declare two
>> layers from GML with only one having the selectFeature associated and it
>> breaks, I can see the icons but no frameCloud appears.
> The clicks aren't getting there.
>> Can you help me? Having nice popups on GeoRSS it's important.
>> View this message in context:
>> http://n2.nabble.com/Popup-problems-on-different-GML-layers-with-GeoRSS-format-tp2886288p2886288.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Christopher Schmidt
> MetaCarta
> Users mailing list
View this message in context: http://n2.nabble.com/Popup-problems-on-different-GML-layers-with-GeoRSS-format-tp2886288p2889389.html
