[OpenLayers-Users] problem about display two layers
Ted Scott
ted.scott at concept-solutions.com
Fri May 15 15:50:00 EDT 2009
I'm having the same problem with all layers having the transparent: true
attribute set. The lower layers are not visible in IE 6. The map renders
fine in FFx.
Christopher Schmidt wrote:
> On Wed, May 13, 2009 at 01:33:22AM -0700, sasi wrote:
>> When i display two layers with openlayers, I can only see the second layer.
>> After i set the second layer opacity=0.5, I can see the both layers. But the
>> line
>> in the second layer seems to be transparent too. And the first layers seems
>> not be very visibility.
>> So, can i change only the background to transparent, and keep the line to be
>> opacity?
> transparent: true parameter in the WMS params.
>> The map comes from geoserver.
>> Thanks!
>> View this message in context: http://n2.nabble.com/problem-about-display-two-layers-tp2879776p2879776.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
