[OpenLayers-Users] problem about display two layers
Christopher Schmidt
crschmidt at metacarta.com
Fri May 15 16:06:56 EDT 2009
On Fri, May 15, 2009 at 03:50:00PM -0400, Ted Scott wrote:
> I'm having the same problem with all layers having the transparent: true
> attribute set. The lower layers are not visible in IE 6. The map renders
> fine in FFx.
Yes. 32-bit PNGs (alpha transparency) are not visible in IE6. Use 8-bit
PNGs or gifs, or don't support IE6. (Microsoft doesn't.)
-- Chris
> Christopher Schmidt wrote:
> > On Wed, May 13, 2009 at 01:33:22AM -0700, sasi wrote:
> >> When i display two layers with openlayers, I can only see the second layer.
> >> After i set the second layer opacity=0.5, I can see the both layers. But the
> >> line
> >> in the second layer seems to be transparent too. And the first layers seems
> >> not be very visibility.
> >> So, can i change only the background to transparent, and keep the line to be
> >> opacity?
> > transparent: true parameter in the WMS params.
> >> The map comes from geoserver.
> >> Thanks!
> >> View this message in context: http://n2.nabble.com/problem-about-display-two-layers-tp2879776p2879776.html
> >> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> Users mailing list
Christopher Schmidt
MetaCarta
