[OpenLayers-Users] problem about display two layers
Kris Geusebroek
kgeusebroek at xebia.com
Fri May 15 17:07:01 EDT 2009
OpenLayers supports IE6 transparency through the alphaHack method.
layer.alpha = setAlpha('image/png');
function setAlpha(imageformat)
var filter = false;
if (imageformat.toLowerCase().indexOf("png") > -1) {
filter = OpenLayers.Util.alphaHack();
return filter;
Cheers Kris
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
On Behalf Of Christopher Schmidt
Sent: Friday, May 15, 2009 10:07 PM
To: Ted Scott
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] problem about display two layers
On Fri, May 15, 2009 at 03:50:00PM -0400, Ted Scott wrote:
> I'm having the same problem with all layers having the transparent:
true
> attribute set. The lower layers are not visible in IE 6. The map
renders
> fine in FFx.
Yes. 32-bit PNGs (alpha transparency) are not visible in IE6. Use 8-bit
PNGs or gifs, or don't support IE6. (Microsoft doesn't.)
-- Chris
> Christopher Schmidt wrote:
> > On Wed, May 13, 2009 at 01:33:22AM -0700, sasi wrote:
> >> When i display two layers with openlayers, I can only see the
second layer.
> >> After i set the second layer opacity=0.5, I can see the both
layers. But the
> >> line
> >> in the second layer seems to be transparent too. And the first
layers seems
> >> not be very visibility.
> >> So, can i change only the background to transparent, and keep the
line to be
> >> opacity?
> > transparent: true parameter in the WMS params.
> >> The map comes from geoserver.
> >> Thanks!
> >> View this message in context:
http://n2.nabble.com/problem-about-display-two-layers-tp2879776p2879776.
html
> >> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> Users mailing list
Christopher Schmidt
MetaCarta
Users mailing list
