[OpenLayers-Users] wiki seems to be broken
Stephen Woodbridge
woodbri at swoodbridge.com
Sat May 23 23:54:48 EDT 2009
Hi all,
The wiki seems to be broken:
http://trac.openlayers.org/wiki
Python Traceback
File "/var/lib/python-support/python2.4/trac/web/main.py", line 387,
in dispatch_request
dispatcher.dispatch(req)
File "/var/lib/python-support/python2.4/trac/web/main.py", line 191,
in dispatch
chosen_handler = self._pre_process_request(req, chosen_handler)
File "/var/lib/python-support/python2.4/trac/web/main.py", line 263,
in _pre_process_request
chosen_handler = f.pre_process_request(req, chosen_handler)
File "/var/lib/python-support/python2.4/trac/versioncontrol/api.py",
line 73, in pre_process_request
self.get_repository(req.authname) # triggers a sync if applicable
line 101, in get_repository
repos = self._connector.get_repository(rtype, rdir, authname)
File
"/var/lib/python-support/python2.4/trac/versioncontrol/svn_fs.py", line
259, in get_repository
repos = SubversionRepository(dir, None, self.log)
File
281, in __init__
self.pool = Pool()
File
158, in __init__
self._pool = core.svn_pool_create(self._parent_pool())
File "/var/lib/python-support/python2.4/svn/core.py", line 248, in
svn_pool_create
return Pool(parent_pool)
File "/var/lib/python-support/python2.4/libsvn/core.py", line 1438,
in svn_pool_create
return apply(_core.svn_pool_create, args)
File "/var/lib/python-support/python2.4/libsvn/core.py", line 5008,
in _wrap
obj.set_parent_pool(self)
File "/var/lib/python-support/python2.4/libsvn/core.py", line 4921,
in set_parent_pool
self._parent_pool = parent_pool or application_pool
File "/var/lib/python-support/python2.4/libsvn/core.py", line 4909,
in <lambda>
__setattr__ = lambda self, name, value: _swig_setattr(self,
apr_pool_t, name, value)
File "/var/lib/python-support/python2.4/libsvn/core.py", line 22, in
_swig_setattr
return _swig_setattr_nondynamic(self,class_type,name,value,0)
File "/var/lib/python-support/python2.4/libsvn/core.py", line 17, in
self.__dict__[name] = value
RuntimeError: instance.__dict__ not accessible in restricted mode
