[OpenLayers-Users] IE6 GIF transparency issue
Linde Ackermans roselinda.ackermans at ec.europa.eu
Tue May 26 05:43:41 EDT 2009
Pete,
I managed to do this in 2 different ways :
	var boundaries = new OpenLayers.Layer.WMS("Layer1",
            "http://your-url",
            { layers: "0,1,2"
              ,transparent: "true"
              ,srs: "EPSG:3035"
	    {'buffer':0, 'format':"image/png", 'isBaseLayer':false,
'transparent':true},
            {'alpha':true}
2. Specify "image/gif" as the format    ( but I think you specify your
format in the wrong place !! )
            "http://your-url",
            { layers: "0,1,2"
              ,srs: "EPSG:3035"
	    {'buffer':0, 'format':"image/gif", 'isBaseLayer':false,
'transparent':true}
Both work in Firefox, IE6 and IE7
Peter Dawn wrote:
> now i need to use IE6, hence my image format needs to be GIF (as you
> know PNG is not supported by IE6).
> so my question is how can i achieve layer transparency with IE6 and
> GIF format. i have tried
> untiled = new OpenLayers.Layer.WMS(
>                     "Locality", "http://localhost:8080/geoserver/wms",
>                         height: '600',
>                         width: '600',
>                         layers: 'my_layer',
>                         styles: '',
>                         transparent: 'TRUE',
>                         format: format,
>                         tiled: 'true',
> but am still not able to achieve transparency. if i use PNG and use
> firefox it works. but i need to use IE6 and hence GIF.
> any help.
> thanks.
> pete.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/IE6-GIF-transparency-issue-tp2972366p2973736.html
