[OpenLayers-Users] WFS-T example won't work because of error in
gears_init.js line 51
Barbara Fiederer
barbara.fiederer at web.de
Tue May 26 08:57:43 EDT 2009
Hi out there,
I'm new to OpenLayers, so this might be an easy problem, but I can't get it solved on my own.
At the moment I try to understand the examples on the OpenLayers.org-Site and to adjust them to my data. The easier ones worked out fine. But now I cannot get a WFS-T example to work. I tried two of them in the examples list of OpenLayers.org and for a last try the WFS-T Demo provided by Geoserver.
Two examples throw the same error in gears_init.js line 51 "factory = new ActiveXObject('Gears.Factory'); ".
I tried to install it, but since I do not have Autocad installed it won't work.
In the end I tried to copy the source text of the geoserver example, that works fine on the geoserver I use and I adjust only the pathnames to css, openLayers-Library and geodata (tasmania) on the same geoserver, but get the same error.
Has anyone got an idea that could help me.
I use FF 3.0.10, OL 2.7 on windows XP
Thanks, Barbara
____________________________________________________________________
Neu: WEB.DE FreeDSL Komplettanschluss mit DSL 6.000 Flatrate und
Telefonanschluss für 17,95 Euro/mtl.!* http://produkte.web.de/go/02/
