[OpenLayers-Users] WMS/WFS getfeature on hover,
problem to display the GML
Martin Ouellet
geomartino at gmail.com
Fri May 29 08:46:45 EDT 2009
Hi Alex,
here's some piece of the code:
// vector layer
layerHover = new OpenLayers.Layer.Vector("Hover");
// wms/wfs layer
layerWMS = new OpenLayers.Layer.WMS(
"regions WMS",
http://spssoww5d.sso.msp.gouv.qc.ca/cgi-wms/mapserv.exe?map=E:/ms4w/msp/wfs/botinSI.map&
{layers: 'BDGA_REGIO_S_POLY_1M',
format: 'image/gif',
transparent: true,
visibility: true
//control to launch wfs call on hover
control = new OpenLayers.Control.GetFeature({
protocol: OpenLayers.Protocol.WFS.fromWMSLayer(layerWMS),
hover: true
//never called, see explanation below
control.events.register("hoverfeature", this, function(e) {
layerHover.addFeatures([e.feature]);
As I said, The WFS call is maded on hover and I can see the GML in the
response. In the request function of the GetFeature.js file:
result.features = void BUT
result.priv.responseText contain the GML response
so when this function is called, nothing happens since result.features is
null/void
request: function(bounds, options) {
options = options || {};
var filter = new OpenLayers.Filter.Spatial({
type: OpenLayers.Filter.Spatial.BBOX,
value: bounds
var response = this.protocol.read({
maxFeatures: options.single == true ? this.maxFeatures :
undefined,
filter: filter,
callback: function(result) {
if(result.code == 1) {
if(result.features.length) {
if(options.single == true) {
this.selectBestFeature(result.features,
bounds.getCenterLonLat(), options);
} else {
this.select(result.features);
} else if(options.hover) {
this.hoverSelect();
} else {
this.events.triggerEvent("clickout");
if(this.clickout) {
this.unselectAll();
// Reset the cursor.
OpenLayers.Element.removeClass(this.map.div,
"olCursorWait");
scope: this
if(options.hover == true) {
this.hoverRequest = response.priv;
2009/5/29 Alexandre Dube <adube at mapgears.com>
> Hi Martin,
> It could be a namespace issue. It would be easier to help if your code.
> The vector layer object should be enough.
> Regards,
> Alexandre
> Martin Ouellet wrote:
>> Hi all,
>> I'am using the getfeature example (getfeature-wfs.html) with my data
>> (mapserver + shp). The WFS call il launch on the hover event and the GML is
>> return correclty (I can see it in firebug) but during the call back
>> (hoverSelect function), the parameter feature is always null (void) so the
>> GML response is not added to my vector layer.
>> any suggestion?
>> MartinO
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090529/daeca2de/attachment.html
