[OpenLayers-Users] Change Layers,
but Layer does not show until zoom out/in performed
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jul 1 11:18:03 EDT 2010
Stephen Woodbridge wrote:
> Hi Chris,
> Thank you for your feedback on changing layers. I got almost everything
> working. I think I ran into the remaining issue a long time ago, but I
> can not for the life of me find the old post or solution. And this might
> not be exactly the same problem.
> I have three base layers:
> 1. Tiger in EPSG:4326
> 2. Google in EPSG:900913
> 3. Streets in EPSG:4326
> and a couple of vector overlays that are always on.
> Everything works fine when I switch between any of the base layers
> EXCEPT when I change from Google to Streets.
It looks like changing from Google to Tiger also fails to draw. I
thought I had tried this before and it was working. But I guess it makes
some sense for consistency sake, but Tiger and Streets are virtually
identical definitions.
-Steve
> When I change from Google to Streets nothing is drawn in the view port.
> No mapserver image, no vector data, just the map controls. If I zoom in
> or out everything displays properly.
> There are no broken images, not javascript errors reported.
> The NET panel shows that the image is requested and received.
> In FF console:
> map.baseLayer.redraw()
> returns true but nothing is displayed.
> Here is the app currently under development:
> http://imaptools.com:8080/routeloops/index4.php?zoom=11&lat=42.64057&lon=-71.36395&layers=B00TT&ll=-71.389033%2042.619456&len=10&rs=0.13877378737528812&av=1100%2C1200&u=E&cw=1#
> To reproduce the issue:
> 1. open the layerswitcher
> 2. select Google Map (click through alerts)
> 3. select Streets (click through alerts) - nothing displays
> 4. zoom in or out - everything displays ok
> Any pointers would be appreciated.
> Thanks,
> -Steve
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
