[OpenLayers-Users] Change Layers,
but Layer does not show until zoom out/in performed
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jul 1 14:31:23 EDT 2010
OK, digging into this problem more I have found out why it is not
displayed and how to hack it to cause it to display, but clearly I have
no idea what I might be doing to cause this.
When I switch from Google to one of the EPSG:4326 layers there are bad
values for:
map.layerContainerDiv.style.left
map.layerContainerDiv.style.top
When I catch the baseLayer changed event I added:
if (map.baseLayer.name != 'Google Map') {
map.layerContainerDiv.style.left = "0px";
map.layerContainerDiv.style.top = "0px";
And this seems to fix the display problem. I'm sure this is not the
intended way to fix this problem and I'm guessing that I am probably
using part of the API in the wrong way. But I have not found who or what
changes those values or why I'm getting numbers like -3e+10
Thanks,
-Steve
>> Hi Chris,
>> Thank you for your feedback on changing layers. I got almost everything
>> working. I think I ran into the remaining issue a long time ago, but I
>> can not for the life of me find the old post or solution. And this might
>> not be exactly the same problem.
>> I have three base layers:
>> 1. Tiger in EPSG:4326
>> 2. Google in EPSG:900913
>> 3. Streets in EPSG:4326
>> and a couple of vector overlays that are always on.
>> Everything works fine when I switch between any of the base layers
>> EXCEPT when I change from Google to Streets.
> It looks like changing from Google to Tiger also fails to draw. I
> thought I had tried this before and it was working. But I guess it makes
> some sense for consistency sake, but Tiger and Streets are virtually
> identical definitions.
> -Steve
>> When I change from Google to Streets nothing is drawn in the view port.
>> No mapserver image, no vector data, just the map controls. If I zoom in
>> or out everything displays properly.
>> There are no broken images, not javascript errors reported.
>> The NET panel shows that the image is requested and received.
>> In FF console:
>> map.baseLayer.redraw()
>> returns true but nothing is displayed.
>> Here is the app currently under development:
>> http://imaptools.com:8080/routeloops/index4.php?zoom=11&lat=42.64057&lon=-71.36395&layers=B00TT&ll=-71.389033%2042.619456&len=10&rs=0.13877378737528812&av=1100%2C1200&u=E&cw=1#
>> To reproduce the issue:
>> 1. open the layerswitcher
>> 2. select Google Map (click through alerts)
>> 3. select Streets (click through alerts) - nothing displays
>> 4. zoom in or out - everything displays ok
>> Any pointers would be appreciated.
>> Thanks,
>> -Steve
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
