[OpenLayers-Users] Open Layers Configuration
Kalyan Kamepalli
kalyan.kamepalli at gmail.com
Mon Jul 5 21:57:32 EDT 2010
Hi Robert,
Thanks for the reply. I just placed my html file in the openLayers folder
and it came out with the default zoom and pan controls on the map. But, the
real problem is that, it's not sending any WMS requests to my Web server. I
wonder, I may have done something wrong. But, couldn't find it.
It worked when I used the openlayers.org/api/openlayers.js reference.But,
now I can not use it as my network is under security control.
But, it should normally be okay when I reference to the local openlayers.js
right ? Any suggestions ??
Thanks,
Kalyan
On Tue, Jul 6, 2010 at 11:31 AM, Robert Sanson <
Robert.Sanson at asurequality.com> wrote:
> I believe the problem is with this line:
> <script src=*'D:\OpenLayers-2.9.1\OpenLayers.js'*></script>
> The browser won't be able to find that location. It needs to be on the Web
> server. If you put it in the same location as your html file, then you can
> just use:
> <script src='*OpenLayers.js'*></script>
> Regards,
> Robert
> >>> Kalyan Kamepalli <kalyan.kamepalli at gmail.com> 6/07/2010 1:00 p.m. >>>
> Hi Group,
> There are few security concerns at my organization and due to that, I can
> not directly access openlayers.org for OpenLayers.js. So, I installed it
> and changed my script as below
> </head>
> <body>
> <div id='map'></div>
> <script type="text/javascript">
> //var map = new OpenLayers.Map('map',{maxResolution: 1000} );
> var map = new OpenLayers.Map('map', {
> maxExtent: new OpenLayers.Bounds(
> -638480920.244,-188017611.367,665489491.580,1019789790.73),
> maxResolution: 5000
> var wmscURL = [
> http://siasporapv01:8080/gss/ogc?version=1.3.0&crs=sw:nsw_trans_mercator_mm&styles=Default
> var myLayer = new OpenLayers.Layer.WMS( 'Cambridge Steet' , wmscURL , {
> layers: 'background' , format: 'image/png'} , { buffer: 1 , isBaseLayer:
> true } );
> map.addLayer( myLayer )
> map.zoomToMaxExtent();
> </script>
> Now the problem is that, It's not showing any controls on the map and
> also not sending any requests to my server. Everything comes out with no
> image tiles.
> If I use openlayers.org/api/openlayers.js on my local machine it works
> perfect.
> Am I missing something ? Is is not the way to configure OpenLayers ?
> Thanks,
> Kalyan
> Click here <https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==> to
> report this email as spam.
> This message has been scanned for malware by SurfControl plc.
> www.surfcontrol.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100706/a69d813d/attachment.html
