[OpenLayers-Users] Open Layers Configuration
Kalyan Kamepalli kalyan.kamepalli at gmail.com
Mon Jul 5 22:32:17 EDT 2010
Robert,
Yes. I did get images with WMS service from my server. I have JBOSS running
on my machine as a web server. I'll place my html and openlayers.jc in
htdocs and give it a go.
On Tue, Jul 6, 2010 at 12:24 PM, Robert Sanson <
Robert.Sanson at asurequality.com> wrote:
>  Hi Kalyan
> Can you get images from your WMS service directly by typing in a URL
> similar to the following in your browser:
> http://siasporapv01:8080/gss/ogc?<http://siasporapv01:8080/gss/ogc?version=1.3.0&crs=sw:nsw_trans_mercator_mm&styles=Default>
> srs=EPSG:2193&exceptions=application/vnd.ogc.se_inimage&version=1.1.1&transparent=true&request=GetMap&service=WMS&styles=&format=image/png&width=512&bbox=1476886.4500139,5133384.9500139,1482121.5499862,5138620.0499862&layers=0,1,11&height=512<http://wmsserver/?srs=EPSG:2193&exceptions=application/vnd.ogc.se_inimage&version=1.1.1&transparent=true&request=GetMap&service=WMS&styles=&format=image/png&width=512&bbox=1476886.4500139,5133384.9500139,1482121.5499862,5138620.0499862&layers=0,1,11&height=512>
> Do you have a local Web server on your machine - such as Apache? In which
> case you would have your html file and the OpenLayer.js file in the htdocs
> directory. Then you would launch it by typing:
> http://localhost/myolmap.html
> regards,
> Robert Sanson
> >>> Kalyan Kamepalli <kalyan.kamepalli at gmail.com> 6/07/2010 2:09 p.m. >>>
>   Another problem with the configuration,
>  I got heaps of the following xml files in my OGC resources folder
>  <ServiceExceptionReport xmlns="*http://www.opengis.net/ogc*" xmlns:xlink
> ="*http://www.w3.org/1999/xlink*" xmlns:xsi="*
> http://www.w3.org/2001/XMLSchema-instance*" version="*1.3.0*"xsi:schemaLocation
> http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd*">
>  **<ServiceException code="*InvalidParameterValue*" locator="*
> application/vnd.ogc.se_inimage*">*Validation failed for parameter
> [exception], value [application/vnd.ogc.se_inimage].*</ServiceException>
>  **</ServiceExceptionReport>
> Is that because I have no access to www.opengis.net ? I have no access no
> any of the above pages. Is this the reason for all my problems ?
> On Tue, Jul 6, 2010 at 11:57 AM, Kalyan Kamepalli <
> kalyan.kamepalli at gmail.com> wrote:
>>  Hi Robert,
>>  Thanks for the reply. I just placed my html file in the openLayers
>> folder and it came out with the default zoom and pan controls on the map.
>> But, the real problem is that, it's not sending any WMS requests to my Web
>> server. I wonder, I may have done something wrong. But, couldn't find it.
>>  It worked when I used the openlayers.org/api/openlayers.jsreference.But, now I can not use it as my network is under security control.
>>  But, it should normally be okay when I reference to the local
>> openlayers.js right ? Any suggestions ??
>>  Thanks,
>> Kalyan
>> On Tue, Jul 6, 2010 at 11:31 AM, Robert Sanson <
>>>  I believe the problem is with this line:
>>>  <script src=*'D:\OpenLayers-2.9.1\OpenLayers.js'*></script>
>>> The browser won't be able to find that location. It needs to be on the
>>> Web server. If you put it in the same location as your html file, then you
>>> can just use:
>>>  <script src='*OpenLayers.js'*></script>
>>> Regards,
>>>  Robert
>>> >>> Kalyan Kamepalli <kalyan.kamepalli at gmail.com> 6/07/2010 1:00 p.m.
>>>   Hi Group,
>>>  There are few security concerns at my organization and due to that, I
>>> can not directly access openlayers.org for OpenLayers.js. So, I
>>> installed it and changed my script as below
>>> </head>
>>> <body>
>>> <div id='map'></div>
>>> <script type="text/javascript">
>>> //var map = new OpenLayers.Map('map',{maxResolution: 1000} );
>>> var map = new OpenLayers.Map('map', {
>>> maxExtent: new OpenLayers.Bounds(
>>> -638480920.244,-188017611.367,665489491.580,1019789790.73),
>>> maxResolution: 5000
>>> var wmscURL = [
>>> var myLayer = new OpenLayers.Layer.WMS( 'Cambridge Steet' , wmscURL , {
>>> layers: 'background' , format: 'image/png'} , { buffer: 1 , isBaseLayer:
>>> true } );
>>> map.addLayer( myLayer )
>>> map.zoomToMaxExtent();
>>> </script>
>>>  Now the problem is that, It's not showing any controls on the map and
>>> also not sending any requests to my server. Everything comes out with no
>>> image tiles.
>>> If I use openlayers.org/api/openlayers.js on my local machine it works
>>> perfect.
>>>  Am I missing something ? Is is not the way to configure OpenLayers ?
>>>  Thanks,
>>> Kalyan
>>> Click here <https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==> to
>>> report this email as spam.
>>> This message has been scanned for malware by SurfControl plc.
>>> www.surfcontrol.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100706/9953d6a5/attachment.html
