[OpenLayers-Users] MergeNewParams / redraw
Sascha Müller
olaiya at arcor.de
Fri Jul 9 03:40:39 EDT 2010
Hi Andreas,
I tried your way.
node.layer.mergeNewParams(
sld_body : sld, // sld is a var with the content SLD_BODY (see
below in the table)
'styles' : ""
The result is still the same. The Legend gets the new Style. The map not.
These are the Parameters Firebug gaves me, when I perform mergeNewParams().
EXCEPTIONS |application/vnd.ogc.se_xml|
FORMAT |image/gif|
LAYER |WL:Gewaesser|
PROJECTION |EPSG:31256|
REQUEST |GetLegendGraphic|
SCALE |125000.1462402|
SERVICE |WMS|
SLD_BODY |||<?xml version="1.0"
encoding="ISO-8859-1"?><StyledLayerDescriptor version="1.0.0"
xmlns="http://www.opengis||.net/sld"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi||="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/sld
http://schemas||.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd"><NamedLayer><Name>Gewaesser</Name><UserStyle><Title||>Gewaesser
Style</Title><Abstract>RGB 204 224
255</Abstract><FeatureTypeStyle><Rule><Title>Polygon</Title||><PolygonSymbolizer><Fill><CssParameter
name="fill">#000000</CssParameter></Fill></PolygonSymbolizer||></Rule></FeatureTypeStyle></UserStyle></NamedLayer></StyledLayerDescriptor>|
TRANSPARENT |true|
VERSION |1.1.1|
The Request ist 'GetLegendGraphic'. Is this right?
Is there a requirement, that the new Style has to be on the GeoServer?
Regards,
Sascha
> On Jul 8, 2010, at 19:53 , BMcBride wrote:
>> Try using styles: instead of sld_body:.
> No. sld_body is correct. But accompany it with
> styles: ""
> in the mergeNewParams object.
> Regards,
> Andreas.
>> Bryan R. McBride, GISP
>> http://www.bryanmcbride.com bryanmcbride.com
>> View this message in context: http://osgeo-org.1803224.n2.nabble.com/MergeNewParams-redraw-tp5271050p5271258.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100709/7024f68b/attachment.html
