[OpenLayers-Users] MergeNewParams / redraw [SOLVED]
Sascha Müller
olaiya at arcor.de
Fri Jul 9 04:04:23 EDT 2010
Hi Andreas,
I changed the Name of the NamedLayer inside the sld.
<NamedLayer>
<Name>Gewaesser</Name>
to
<NamedLayer>
<Name>WL:Gewaesser</Name>
Now, it works.
Thanks a lot!
regards,
Sascha
> Hi Andreas,
> I tried your way.
> node.layer.mergeNewParams(
> sld_body : sld, // sld is a var with the content SLD_BODY (see
> below in the table)
> 'styles' : ""
> The result is still the same. The Legend gets the new Style. The map not.
> These are the Parameters Firebug gaves me, when I perform
> mergeNewParams().
> EXCEPTIONS |application/vnd.ogc.se_xml|
> FORMAT |image/gif|
> LAYER |WL:Gewaesser|
> PROJECTION |EPSG:31256|
> REQUEST |GetLegendGraphic|
> SCALE |125000.1462402|
> SERVICE |WMS|
> SLD_BODY |||<?xml version="1.0"
> encoding="ISO-8859-1"?><StyledLayerDescriptor version="1.0.0"
> xmlns="http://www.opengis||.net/sld"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi||="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/sld
> http://schemas||.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd"><NamedLayer><Name>Gewaesser</Name><UserStyle><Title||>Gewaesser
> Style</Title><Abstract>RGB 204 224
> 255</Abstract><FeatureTypeStyle><Rule><Title>Polygon</Title||><PolygonSymbolizer><Fill><CssParameter
> name="fill">#000000</CssParameter></Fill></PolygonSymbolizer||></Rule></FeatureTypeStyle></UserStyle></NamedLayer></StyledLayerDescriptor>|
> TRANSPARENT |true|
> VERSION |1.1.1|
> The Request ist 'GetLegendGraphic'. Is this right?
> Is there a requirement, that the new Style has to be on the GeoServer?
> Regards,
> Sascha
>> On Jul 8, 2010, at 19:53 , BMcBride wrote:
>>> Try using styles: instead of sld_body:.
>> No. sld_body is correct. But accompany it with
>> styles: ""
>> in the mergeNewParams object.
>> Regards,
>> Andreas.
>>> Bryan R. McBride, GISP
>>> http://www.bryanmcbride.com bryanmcbride.com
>>> View this message in context:http://osgeo-org.1803224.n2.nabble.com/MergeNewParams-redraw-tp5271050p5271258.html
>>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100709/cb518a49/attachment.html
