[OpenLayers-Users] Working with Openlayers.Layer.Vector and WFS
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Fri Jul 16 09:56:05 EDT 2010
Without seeing your actual WFS it is hard to help.
But here it goes:
1) featureType should be MonkeyIsland
2) check if your featureNS does not end with / in the XML returned by your
WFS, this would also break the parser. So maybe
http://www.mapinfo.com/wfs/ instead of http://www.mapinfo.com/wfs
Best regards,
Bart
> Hello
> I'm having a real hard time changing my OpenLayers.Layer.WFS request to
> the
> OpenLayers.Layer.Vector with OpenLayers.Protocol.WFS. I've been reading
> and
> experimenting all available examples that I was able to find and the API
> documentation (wich, by the way, didn't help very much) for 2 days now and
> couldn't get it to work.
> So, please, can someone tell why this old fashion request has a
> successfull
> response:
> var wfs = new OpenLayers.Layer.WFS("Guybrush Threepwood",
> "http://localhost:2006/GetFeature.ashx",
> { typename:
> "miwfs:MonkeyIsland"
> }, { 'projection': new
> OpenLayers.Projection("EPSG:4326")
> , 'displayProjection': new
> , 'maxExtent': new
> OpenLayers.Bounds(-9.517034, 36.961718, -6.189968, 42.15434)
> , 'maxResolution':
> 156543.0339
> , 'numZoomLevels': 21
> , 'minZoomLevel': 1
> , 'maxZoomLevel': 21
> , 'units': "dd"
> , 'encodeBBOX': true
> , 'displayOutsideMaxExtent':
> true
> , 'styleMap': layerStyle
> , 'extractAttributes': true
> map.addLayer(wfs);
> But this one, that I found somewhere in the examples or forums, doesn't:
> var layer = new OpenLayers.Layer.Vector("Guybrush Threepwood", {
> strategies: [new OpenLayers.Strategy.BBOX()],
> protocol: new OpenLayers.Protocol.WFS({
> version: "1.1.0",
> url: "http://localhost:2006/GetFeature.ashx",
> featureType: "miwfs:MonkeyIsland",
> featureNS: "http://www.mapinfo.com/wfs",
> geometryName: "VL_GMTR",
> srsName: "EPSG:4326"
> projection: new OpenLayers.Projection("EPSG:4326")
> map.addLayer(wfs);
> If helps, my map object is:
> var map = new OpenLayers.Map("map", {
> projection: new OpenLayers.Projection("EPSG:900913"),
> units: "m",
> maxResolution: 156543.0339,
> maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34,
> 20037508.34, 20037508.34),
> numZoomLevels: 21
> and my baseMap is:
> var myBaseLayer = new OpenLayers.Layer.Google("Google",
> { 'sphericalMercator': true
> , 'minZoomLevel': 1
> map.addLayer(myBaseLayer);
> Sorry for the long post.
> Edu
> http://osgeo-org.1803224.n2.nabble.com/Working-with-Openlayers-Layer-Vector-and-WFS-tp5301971p5301971.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Looking for flexible support on OpenLayers or GeoExt? Please check out
http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
