[OpenLayers-Users] MapFish vs OpenLayers
Yves Moisan
yves.moisan at boreal-is.com
Fri Jul 16 11:29:30 EDT 2010
Le 2010-07-16 11:19, Gilberto Ramos a écrit :
> Mapfish client = GeoExt + Openlayers
> GeoExt = ExtJS + Openlayers
> I use Mapfish just as client! It has very nice widgets that would safe you a
> couple of hours coding.. The result is the same you would obtain coding with
> GeoExt because both use ExtJS
I don't know to which extent the client side of MapFish is now GeoExt.
I suspect there are still MapFish only widgets. MF folks : correct me
if I'm wrong.
A lot of MF widgets (e.g. the layertree) are now obsolete in favor of
their GeoExt replacement widgets. I just don't know to which extent all
the MF widgets have been replaced with/ported to GeoExt. But the plan
is to eliminate most of the client side of MF in favor of GeoExt.
Cheers,
Yves
