[OpenLayers-Users] SphericalMercator and SRS aliases epsg:900913, epsg:3857, epsg:3785, epsg:102113
Bart van den Eijnden bartvde at osgis.nl
Mon Jul 19 12:48:30 EDT 2010
Hi Anne,
the best way for documentation fixes/additions is to create a patch (svn diff or unified diff) on the rst document (available in svn) and create a Trac ticket with the patch attached. TIA.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Jul 19, 2010, at 5:37 PM, Anne Blankert wrote:
>  Thanks for pointing to this fairly complete documentation. However,
> the subject of why and how to use the epsg:900913 aliases and the
> caveats is not yet included. I've added a section "SphericalMercator and
> EPSG aliases" to http://trac.openlayers.org/wiki/SphericalMercator.
> I don't think users can edit documentation such as
> http://docs.openlayers.org/library/spherical_mercator.html
> directly can they?
> Anne
>>>  Hello Bart,
>>> My 2 cents:
>>> In my opinion it is quite difficult for users to discover:
>>> - OpenStreetMap, Google, Bing, Yahoo etc. use a projection called
>>> 'SphericalMercator'
>>> - 'SphericalMercator' in OpenLayers uses code 'epsg:900913'
>> I think this is reasonably well documented in
>> and if you search for:
>>  http://docs.openlayers.org/search.html?q=google+projection
>> You get that as one of the results. (Not as highly ranked as I would
>> like, I'll admit, but it is there.)
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
