[OpenLayers-Users] externalGraphic anchoring points?
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jul 27 12:14:16 EDT 2010
I believe the origin of an image is the upper-left corner, so you need
to specify your offsets based on that point.
-Steve
William Martin wrote:
> All,
> Hi, new user. I'm using a vector layer for placing markers on the map, and I'm using the externalGraphic property to specify a marker of my own. How is that image anchored with respect to the lat/lon coordinates that it represents?
> That is, if exactly one pixel in the external graphic corresponds to the point on the map, is it:
> a) The top left corner pixel
> b) The top right corner pixel
> c) The bottom left corner pixel
> d) The bottom right corner pixel
> e) The exact center pixel
> f) A pixel halfway along one edge
> Or g) something else entirely?
> I need to know so that I can figure out the correct offsets to use with my graphic.
> I tried to figure this out by using an external graphic for the marker which was a 1x1 pixel animated GIF blinking red/white/red/white and then defining another marker for the same coordinates with a translucent version of the regular image. But the 1x1 graphic refused to show up, even when I disabled the other marker so that it was on its own. Weird.
> Thanks!
> Will Martin
> Web Services Librarian
> Chester Fritz Library, University of North Dakota
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
