[OpenLayers-Users] externalGraphic anchoring points?
christopher.schmidt at nokia.com
Tue Jul 27 13:20:23 EDT 2010
On Jul 27, 2010, at 12:14 PM, ext Stephen Woodbridge wrote:
> I believe the origin of an image is the upper-left corner, so you need
> to specify your offsets based on that point.
I don't think so. I believe externalGraphics center, by default, on the
center of the image. (I don't know what happens for images where this is
a half pixel; I assume we round somehow, but I don't know how.)
-- Chris
> -Steve
> William Martin wrote:
>> All,
>> Hi, new user. I'm using a vector layer for placing markers on the map, and I'm using the externalGraphic property to specify a marker of my own. How is that image anchored with respect to the lat/lon coordinates that it represents?
>> That is, if exactly one pixel in the external graphic corresponds to the point on the map, is it:
>> a) The top left corner pixel
>> b) The top right corner pixel
>> c) The bottom left corner pixel
>> d) The bottom right corner pixel
>> e) The exact center pixel
>> f) A pixel halfway along one edge
>> Or g) something else entirely?
>> I need to know so that I can figure out the correct offsets to use with my graphic.
>> I tried to figure this out by using an external graphic for the marker which was a 1x1 pixel animated GIF blinking red/white/red/white and then defining another marker for the same coordinates with a translucent version of the regular image. But the 1x1 graphic refused to show up, even when I disabled the other marker so that it was on its own. Weird.
>> Thanks!
>> Will Martin
>> Web Services Librarian
>> Chester Fritz Library, University of North Dakota
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
