[OpenLayers-Users] externalGraphic anchoring points?
MostlyBaldEagle
MostlyBaldEagle at shaw.ca
Tue Jul 27 14:02:37 EDT 2010
It's the center of the image.
Easy to see if you connect two images with a line :-)
Make sure the line feature is added to the layer before the two images(point
features), then the line will usually show up on top.
See example:
http://osgeo-org.1803224.n2.nabble.com/file/n5343347/test_2_8.htm
test_2_8.htm
View this message in context: http://osgeo-org.1803224.n2.nabble.com/externalGraphic-anchoring-points-tp5342684p5343347.html
