[OpenLayers-Users] externalGraphic anchoring points?
William Martin
williammartin at mail.und.nodak.edu
Tue Jul 27 15:13:34 EDT 2010
That's exactly the information I needed - and with a clear example as well! Thanks.
Will Martin
>>> MostlyBaldEagle <MostlyBaldEagle at shaw.ca> Tue 27 July 2010 1:02 PM >>>
It's the center of the image.
Easy to see if you connect two images with a line :-)
Make sure the line feature is added to the layer before the two images(point
features), then the line will usually show up on top.
See example:
http://osgeo-org.1803224.n2.nabble.com/file/n5343347/test_2_8.htm
test_2_8.htm
View this message in context: http://osgeo-org.1803224.n2.nabble.com/externalGraphic-anchoring-points-tp5342684p5343347.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
