[OpenLayers-Users] Resolutions with Geowebcache and
WMSGetFeatureInfo [Sec=Unclassified]
Tim Schaub
tschaub at opengeo.org
Thu Jul 29 15:30:20 EDT 2010
Hi Miles-
GeoWebCache supports the WMTS standard. The WMTS standard defines a
GetFeatureInfo method (with different semantics than the WMS
GetFeatureInfo method). OpenLayers (true) provides a WMTS layer. I've
got a patch outstanding to add a WMTS GetFeatureInfo control. This, in
my mind, is the way to get feature info from a tile service.
A few tickets need addressing before this would be entirely useful to
you. You can watch this one if you're interested:
http://trac.openlayers.org/ticket/2678
I'll try to find some time to finish that up in the near future.
Tim
On 7/28/10 6:00 PM, Miles Jordan wrote:
> Hi Andreas,
> Thanks. That method works, but I was hoping I could get geowebcache
> to work so that clients that consume data from us can access both
> maps and getfeatureinfo from the one url. Ideally I would like to
> have geoserver completely inaccessible from outside the firewall,
> with geowebcache being the only way to access it. Your suggestion
> will do the trick for the time being though.
> Regards,
> Miles
> Andreas Hocevar wrote:
>> Hi,
>> the problem I see with your approach is that
>> OpenLayers.Control.GetFeatureInfo creates a GetFeatureInfo request
>> for the map extent, not for a tile. I would recommend sending
>> GetFeatureInfo requests to the underlying WMS, as explained in
>> http://getsatisfaction.com/opengeo/topics/error_in_wmsgetfeatureinfo#r
eply_2612983
>> Regards, Andreas.
>> On Jul 27, 2010, at 08:55 , Miles Jordan wrote:
>>> Hi,
>>> I've been debugging a problem that I've been having with using
>>> the WMSGetFeatureInfo control and GeoWebCache.
>>> Basically I am setting OpenLayers.DOTS_PER_INCH to
>>> 90.71428571428572
>> which is what GeoWebCache expects by default, however when the
>> WMSGetFeatureInfo request goes through to GeoWebCache it is like
>> it's using the default 72 for DOTS_PER_INCH, because all of the
>> resolutions are about 21% out.
>>> GeoWebCache responds with messages such as :"400: Requested
>> horizontal resolution: 0.54931640625 , best match: 0.703125
>> exceeds 10% threshold. Perhaps the client is configured with an
>> incorrect set of scales (resolutions), or the DPI setting is off
>> compared to the one in GWC ?"
>>> I've actually just dropped the WMSGetFeatureInfo control into a
>> GeoWebCache OpenLayers demo, so the resolutions are definitely set
>> up to match. The full source (pretty short and simple) is at
>> http://pastebin.com/JENnAPC9.
>>> I've brought it up on the GeoWebCache mailing list but now
>>> thinking that it's more likely something to do with OpenLayers.
>>> Here's a link to my messages: http://tinyurl.com/38jvcva
>>> It seems like the resolution would be calculated incorrectly by
>> about that amount if the DOTS_PER_INCH were still at 72, so I'm
>> wondering if there's another setting that I need to change or if
>> there's a bug somewhere.
>>> Your comments are appreciated.
>>> Regards,
>>> Miles Jordan Acting Manager / Systems Analyst Australian
>>> Antarctic Data Centre Australian Antarctic Division Dept. of the
>>> Environment, Water, Heritage& the Arts
>>> ______________________________________________________________________
_____
>>> Australian Antarctic Division - Commonwealth of Australia
>>> IMPORTANT: This transmission is intended for the addressee only.
>>> If you are not the intended recipient, you are notified that use
>>> or dissemination of this communication is strictly prohibited by
>>> Commonwealth law. If you have received this transmission in
>>> error, please notify the sender immediately by e-mail or by
>>> telephoning +61
>> 3 6232 3209 and DELETE the message.
>>> Visit our web site at http://www.antarctica.gov.au/
_____ _______________________________________________ Users mailing
>>> list Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Regards,
> Miles
> ___________________________________________________________________________
> Australian Antarctic Division - Commonwealth of Australia IMPORTANT:
> This transmission is intended for the addressee only. If you are not
> the intended recipient, you are notified that use or dissemination of
> this communication is strictly prohibited by Commonwealth law. If you
> have received this transmission in error, please notify the sender
> immediately by e-mail or by telephoning +61 3 6232 3209 and DELETE
> the message. Visit our web site at http://www.antarctica.gov.au/
> Users mailing list Users at openlayers.org
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
