[OpenLayers-Users] RE: Google Terrian map does not align with
geometry
Nicholas Efremov-Kendall
n.e.kendall at gmail.com
Wed Jun 15 17:20:03 EDT 2011
rather, the layers can support different zoom levels, maybe there's a
conflict there.
On Wed, Jun 15, 2011 at 4:18 PM, Nicholas Efremov-Kendall <
n.e.kendall at gmail.com> wrote:
> Hi JK,
> The googles layers actually have different zoom levels, sometimes going to
> hybrid goes to 21, physical goes to 22 and such. Look up the maxzoom for the
> terrain layer, that might fix your problem.
> On Wed, Jun 15, 2011 at 4:05 PM, JK Chen <jk.chen at sdl.usu.edu> wrote:
>> These misalignments happen at zoom levels greater than or equal to 16. As
>> you might know, Google Terrain provides 20 zoom levels. Apparently this is
>> a bug within Openlayers.
>> My current “workaround” is to set the numZoomlevels to 16 for Google
>> Terrain map.
>> Thanks.
>> JK
>> *From:* openlayers-users-bounces at lists.osgeo.org [mailto:
>> openlayers-users-bounces at lists.osgeo.org] *On Behalf Of *JK Chen
>> *Sent:* Wednesday, June 15, 2011 1:52 PM
>> *To:* openlayers-users at lists.osgeo.org
>> *Subject:* [OpenLayers-Users] Google Terrian map does not align with
>> geometry
>> Hi,
>> My application draws many geometries (basically, polygons, each
>> representing captured aerial images). All of my geometries align correctly
>> with Google Street, Satellite, Hybrid maps, but not correctly with Google
>> Terrian map.
>> While in Google Terrian map, when I zoom in to say zoom levels more than
>> 10, the mis-alignment starts to show up, and another issue also starts
>> showing up, the rectangle of my geometry becomes movable. All of these are
>> simply wrong. These will render the application unreliable which means
>> useless for our users.
>> Can anyone share some thoughts about these behaviors? How to fix them?
>> How Reliable is OpenLayers? I’m seeing many un-reliability and
>> inconsistence.
>> Thanks.
>> JK
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20110615/2a263c4b/attachment-0001.html
