[OpenLayers-Users] Re: Adding querystring parameter containing
current map resolution
BMcBride
bmcbride at opengeo.org
Wed May 4 09:57:40 EDT 2011
Steve,
You could register a moveend event for your layer, which would refresh the
layer and pass in your URL parameters. I'm not sure if this would conflict
with your BBOX strategy, but you could use this method to build your own
custom strategy instead.
map.events.register("moveend", this, function () {
if (MyLayer.getVisibility() === true) {
refreshMyLayer();
function refreshMyLayer() {
var resolution = map.getResolution();
MyLayer.refresh({
force: true,
params: {
res: resolution
Bryan McBride, GISP
OpenGeo - http://opengeo.org
Expert service straight from the developers.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Adding-querystring-parameter-containing-current-map-resolution-tp6330545p6330926.html
