AW: [OpenLayers-Users] OpenLayers.Layer.GML and showing name= of
	OSMdata
    Arnd Wippermann
    arnd.wippermann at web.de
    Thu May 26 12:43:11 EDT 2011
You can get access to the attributes by feature.attributes["amenity"] ...
To get some labels from two attributes use a styleMap with context. With the
below code you should be able to show your labels.
Arnd
var styleMapLabelDS; //DS default and select style
function set_styleMapLabelDS()
    var context = {
        getName : function (ft){
            var label1 = "";
            var label2 = "";
            var theLabel = "";
            if(ft.attributes.name != undefined)
                label1 = ft.attributes.name;
            if(ft.attributes["karuia:CAP"] != undefined)
                label2 = ft.attributes["karuia:CAP"];
            if(label1 != "" && label2 != "")
                theLabel = label1 + ", " + label2;
            else if(label1 != "")
                theLabel = label1;
            else if(label2 != "")
                theLabel = label2;
            return theLabel;
    var template = {
        strokeColor: "#0000FF",
        strokeOpacity: 1,
        strokeWidth: 3,
        fillColor: "#00AAFF",
        fillOpacity: 1,
        pointRadius: 5,
        pointerEvents: "visiblePainted",
        label : "${getName}",
        labelXOffset: "10",
        labelYOffset: "-10",
        fontColor: "blue",
        fontSize: 10,
        fontFamily: "Arial",
        fontWeight: "bold",
        labelAlign: "lt"
    var templateB = {
        strokeColor: "#FFFF00",
        strokeOpacity: 1,
        strokeWidth: 3,
        fillColor: "#FFFF00",
        fillOpacity: 1,
        pointRadius: 5,
        labelXOffset: "10",
        fontColor: "red",
        fontSize: 10,
        fontWeight: "bold",
        labelAlign: "lt"
    styleMapLabelDS = new OpenLayers.StyleMap( { "default" : new
OpenLayers.Style(template, {context:context}), "select" : new
OpenLayers.Style(templateB, {context:context}) } );
set_styleMapLabelDS();
Transports["styleMap"]=styleMapLabelDS;
Transports.redraw();
-----Ursprüngliche Nachricht-----
Von: openlayers-users-bounces at lists.osgeo.org
[mailto:openlayers-users-bounces at lists.osgeo.org] Im Auftrag von Hendrik
Oesterlin
Gesendet: Donnerstag, 26. Mai 2011 12:07
An: openlayers-users at lists.osgeo.org
Betreff: [OpenLayers-Users] OpenLayers.Layer.GML and showing name= of
OSMdata
Hello,
I'm trying to make an overlay to display some circle and the name of bus
stops using OpenStreetMap data.
I have extracted the amenity=bus_station and highway=bus_stop using osmosis.
I have figured out how to put some circle over the map to show the bus stops
using this code:
var Transports = new OpenLayers.Layer.GML("Transports", "arrets-bus.osm",
{format: OpenLayers.Format.OSM, styleMap:new OpenLayers.StyleMap({
"default": {
pointRadius: 4,
fillColor: "#00DD00",
strokeColor: "#ff0000",
fillOpacity: 0.2
map.addLayer(Transports);
An example is here: http://oesterlin.ile.nc/test/20110526atelier.html
I was not able to display any name= or other custom key beside or below the
circles. In this example, displaying "name=" and "karuia:MNCP=" would be
useful.
Is there a possibility to make OpenLayers filter by itself the required key
from an OpenStreetMap-XML file and display the contents?
Can someone give me some hints or even better some example how to do this?
Many thanks!
Hendrik Oesterlin
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
