AW: [OpenLayers-Users] OpenLayers.Layer.GML and showing name= of
OSMdata
Hendrik Oesterlin
hendrikmail2002 at yahoo.de
Fri May 27 03:40:17 EDT 2011
"Arnd Wippermann" arnd.wippermann at web.de wrote on 27/05/2011 at 03:43:11 +1100
subject "AW: [OpenLayers-Users] OpenLayers.Layer.GML and showing name= of OSMdata" :
> You can get access to the attributes by feature.attributes["amenity"] ...
> To get some labels from two attributes use a styleMap with context. With the
> below code you should be able to show your labels.
> Arnd
> var styleMapLabelDS; //DS default and select style
> function set_styleMapLabelDS()
> var context = {
> getName : function (ft){
> var label1 = "";
> var label2 = "";
> var theLabel = "";
> if(ft.attributes.name != undefined)
> label1 = ft.attributes.name;
> if(ft.attributes["karuia:CAP"] != undefined)
> label2 = ft.attributes["karuia:CAP"];
> if(label1 != "" && label2 != "")
> theLabel = label1 + ", " + label2;
> else if(label1 != "")
> theLabel = label1;
> else if(label2 != "")
> theLabel = label2;
> return theLabel;
> var template = {
> strokeColor: "#0000FF",
> strokeOpacity: 1,
> strokeWidth: 3,
> fillColor: "#00AAFF",
> fillOpacity: 1,
> pointRadius: 5,
> pointerEvents: "visiblePainted",
> label : "${getName}",
> labelXOffset: "10",
> labelYOffset: "-10",
> fontColor: "blue",
> fontSize: 10,
> fontFamily: "Arial",
> fontWeight: "bold",
> labelAlign: "lt"
> var templateB = {
> strokeColor: "#FFFF00",
> strokeOpacity: 1,
> strokeWidth: 3,
> fillColor: "#FFFF00",
> fillOpacity: 1,
> pointRadius: 5,
> labelXOffset: "10",
> fontColor: "red",
> fontSize: 10,
> fontWeight: "bold",
> labelAlign: "lt"
> styleMapLabelDS = new OpenLayers.StyleMap( { "default" : new
> OpenLayers.Style(template, {context:context}), "select" : new
> OpenLayers.Style(templateB, {context:context}) } );
> set_styleMapLabelDS();
> Transports["styleMap"]=styleMapLabelDS;
> Transports.redraw();
Thank you very much! This example helps me a lot.
Sincerely
Hendrik Oesterlin - email hendrikmail2002 at yahoo.de
