[OpenLayers-Users] Adjusting Zoom Level Based on Points
Imran Rajjad
rajjad at gmail.com
Tue Nov 8 08:55:15 EST 2011
if the points are in your vector layer, you can get the extent of that
layer and set zoom accordingly
On Tue, Nov 8, 2011 at 4:48 PM, Tac Tacelosky <tacman at gmail.com> wrote:
> As you're going through the points, keep track of the min/max x and y,
> then use those values to set the extent (the boundaries).
> While you can do this in Javascript, we ended up doing that calculation in
> the server-side call that got the points, and sending it over with the json
> that used to populate the array of points.
> Tac
> On Tue, Nov 8, 2011 at 8:30 AM, BalaVignesh Kasinathan <
> kbalavignesh at gmail.com> wrote:
>> Hi,
>> I want to draw the line (route using x,y coordinate points) over the
>> map as vector layer. After route drawn on map, i want to adjust the zoom
>> level to show the complete route. How can i do this? Is there any direct
>> way to do this? If not how to do using math calculations?
>> Regards,
>> Bala
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Users mailing list
I.R
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20111108/db8c9dd6/attachment.html
