[OpenLayers-Users] Re: Move OpenLayers.Popup.FramedCloud up to 10
pixel...
teknocreator
teknocreator at gmail.com
Wed Mar 28 18:42:30 EDT 2012
Paul,
A possible solution:
var pix = new OpenLayers.Pixel();
pix = feature.geometry.getBounds().getCenterPixel(); // assuming you can
access feature
var newpix = new OpenLayers.Pixel();
newpix = pix.add(0,-10); // newpix = pix.x and pix.y-10, where y decreases
going up;
popup = new OpenLayers.Popup.FramedCloud("popupSelect",
map.getLonLatFromPixel(newpix), // assuming map
is global
new OpenLayers.Size(100, 100),
"popup xx contents<br>TEST TEST <br> *
asdsadsadasdas*",
null, true, onPopupClose);
There may be an easier way than this, though. I've tested it as if I was
clicking on a point where the popup should appear and the popup was offset
by the values I entered. Hope it works for the
feature.geometry.getBounds().getCenterPixel() as well.
Dave M
View this message in context: http://osgeo-org.1560.n6.nabble.com/Move-OpenLayers-Popup-FramedCloud-up-to-10-pixel-tp4661702p4666003.html
